Which tool for moving tiny trim pots..?
bemushroomed
Post by bemushroomed » Fri Feb 07, 2020 12:52 pm
Like this one on the SY0.5 eurorack module:
I've manged to move such pots on the x0x heart, but they were much looser as i recall it, i just used this tiny screw driver (for watches and whatever its for). Does not work here.. Maybe there's a specific tool to turn these things, im not a DIY guy.
Thanks.
bemushroomed
Re: Which tool for moving tiny trim pots..?
Post by bemushroomed » Fri Feb 07, 2020 1:13 pm
never mind, i found another tiny screw driver, this one worked better (standard, non star shaped, whatever its called in english lol)
cackland
Post by cackland » Fri Feb 07, 2020 1:32 pm
Deleted. Misread and thought you said re-moving instead of 'moving'.
bemushroomed
Post by bemushroomed » Fri Feb 07, 2020 2:56 pm
no problem.
is there a specific tool you DIY'ers use for this though (to turn these things)? just a tiny screw driver?
gbiz
Post by gbiz » Fri Feb 07, 2020 3:19 pm
You need a "trimmer adjustment tool". eg https://uk.rs-online.com/web/p/trimmer- ... s/8524614/
One end is a regular screwdriver blade, the other end has a recessed blade, great for use with regular multi-turn trimmers as it's less likely to slip off.
cackland
Post by cackland » Fri Feb 07, 2020 3:36 pm
A Phillips head screw driver with the appropriate bit works for me.
bemushroomed
Post by bemushroomed » Sat Feb 08, 2020 1:07 pm
Good to know, thanks!
