HELP Please. New DIY builder- Erica Synths VCA not working
Moderators: lisa, Kent, Joe.
Beepblip
Post by Beepblip » Wed Feb 12, 2020 7:24 am
I have built an Erica Synths Polivocks VCA sourcing my own components using the Erica BOM but it's not working properly. I've followed instructions for calibration with a sine wave in to CV1. There is sound but the trim pots don't do anything. On CV2 there is no sound - nothing. I'm working my way through the schematics and going over every component. Any advice greatly received.
guest
Re: HELP Please. New DIY builder- Erica Synths VCA not working
Post by guest » Wed Feb 12, 2020 1:20 pm
ill pull up the schematics and see what i can find, but in the meantime i would suggest reflowing your solder joints. its pretty quick to do, and 80% of the time thats the problem. pay particular attention to ground connections, and use flux if they arent coming out right.
openmusiclabs.com
guest
Post by guest » Wed Feb 12, 2020 2:40 pm
if one side works and not the other, you can try swapping ICs to see if its a bad IC. perhaps comparing voltages on the good and bad ICs would help narrow down the issue.
openmusiclabs.com
Beepblip
Post by Beepblip » Thu Feb 13, 2020 4:07 pm
Thanks for the tips, resoldered and checked for earth, it's now working. Thanks.
