Adding S-trig gate to Yarns/marbles
Moderators: lisa, Kent, Joe.
pix
Post by pix » Fri Feb 14, 2020 12:39 am
Is there any reason for why this wouldn't work? From a hardware point of view.
Shledge
Re: Adding S-trig gate to Yarns/marbles
Post by Shledge » Fri Feb 14, 2020 6:57 am
It would need a voltage source as s-trig alone doesn't provide a voltage, but rather short it.
fitzgreyve
Post by fitzgreyve » Fri Feb 14, 2020 9:16 am
As this is for yarns/marbles, I assume you mean an s-trig output.
In it's simplest form, that just needs a resistor and a general purpose NPN transistor (e.g. BC547) for each s-trig output. Resistor 10k, 47k or so.
Existing (V-trig) gate in on left, s-trig output on right.
It's just about possible to build this into an adaptor cable.
Under developement:
- "Muse"
https://fitzgreyve2.blogspot.com/
