tape head amp question
Moderators: lisa, Kent, Joe.
alankalter
Post by alankalter » Fri Feb 14, 2020 1:23 am
Hi folks. I wired a 1/8" tape head from a walkman type player to a eurorack patch cable and put it through the Music Thing Modular Mikrophonie to amplify it but the output was still unusably low when i run the head over some tape that I attached flat to some cardboard.
I don't know much about tape heads. could someone suggest a solution to make this work ? I imagine i have the wrong amp?
Here's a pic
Thanks for your help!
T
butter
Re: tape head amp question
Post by butter » Fri Feb 14, 2020 2:33 am
fg
Post by fg » Fri Feb 14, 2020 3:18 am
yes magnetophon, schema is here
https://github.com/TomWhitwell/Magnetophon
Graham Hinton
Post by Graham Hinton » Fri Feb 14, 2020 10:45 am
An 1/8" cassette tape has four tracks so they are less than 1/32" wide (with gaps). The head has the same dimensions, so it will be difficult to align them by hand and get a maximum signal. The head has to be perpendicular to the tape to get the gap on the tape and also the amplitude is proportional to speed. You will need a decent mic pre with over 60dB gain.
You would get better results with 1/4" tape and a 1/2 track head.
alankalter
Post by alankalter » Fri Feb 14, 2020 3:52 pm
Thanks for all the info! I'm gonna get that magnetophone. I should have guess that Music Thing would have done something like that!
