CGS501 NCOM Build
- the bad producer
CGS501 NCOM Build
CGS 501, the new Elby Serge NCOM, anyone built one?
4U panels for sale/4U wiring diagrams/4U stuff here: http://www.loudestwarning.co.uk/
And here, http://loudestwarning.tumblr.com/
https://www.instagram.com/loudestwarning/
Re: CGS501 NCOM Build
Yes, finished mine a few days ago! But stupid as i was i mounted the power connector the wrong way around and likely blew the CD4520 (note to self, never solder until 0430 in the morning, haha)
About to build one?
About to build one?
- dankalmanson
- Learning to Wiggle
I just started on the V 0.2 CGS501. I am assuming there is no chicklet PCB but none of the build documents have been updated. I am assuming U401 is Lm317Z. I am wondering if R117should still be wired to R108 or is that fixed in the PCB?
Hmmm, strange...When i built my second v.01 a few months back i think that the build documents for the V.02 version was linked and that you had to navigate from there to go to the v 01 documents, strange that you end up with the 0.1 docs now. Maybe just email Laurie and ask if they are available and up to date? He's usually very fast at responding.
- Flareless
I'm building the v0.1PCB and while the Comparator section seems fine the Division section isn't working. It seems that there are only millivolts on Pin # 1 of U101 (RC4558) instead of the zero to minus five volts I should be seeing. There also appears to be only millivolts going into Pins #2 and #3 of U101.
I can't find any visual soldering issues. The chicklet board is mounted fine and produces 5.155V
I should mention that the power supply is +/- 15V
@Nisse_D - Did you have to do anything outside of the capacitor on the back and the R117 patch?
