col
- Veteran Wiggler
col
- Veteran Wiggler
Post
by col » Fri Feb 28, 2020 11:16 pm
To find the power supply on Ebay just search for: HIFI Low Noise Single Voltage To Positive Negative Regulated Power Supply Module.
EATyourGUITAR
- has no life
Post
by EATyourGUITAR » Sat Feb 29, 2020 10:40 am
I could have 3Dprinted a nicer box for a small fee. The shipping would be expensive to Australia. Also, Australia likes to smash the boxes before they deliver them.
col
- Veteran Wiggler
Post
by col » Sat Feb 29, 2020 6:33 pm
My phone photos are a bit naff, the boxes actually look a lot better than that. Will add some nicer pix.
aandreari
- Learning to Wiggle
Post
by aandreari » Wed Dec 09, 2020 6:31 pm
hello @Col may i can ask you a couple of questions? how much it will power up + rail? after some months is it still working? any troubles? i would like to build one for a diy case that i would use to just test new diy modules.
thanks
col
- Veteran Wiggler
Post
by col » Wed Dec 09, 2020 7:08 pm
aandreari wrote: ↑Wed Dec 09, 2020 6:31 pm
thanks
Yes, both of mine are still working. One has become a permanent enclosure for my Euroscope V2 and the other one I just use for testing modules that I have built. I don't know what the maximum output current is but I haven't had any issues powering any of my modules. If the XL6008 datasheet is anything to go by the devices are rated to 3A. The bottleneck is more likely to be the USB supply.
http://www.xlsemi.com/datasheet/XL6008%20datasheet.pdf
aandreari
Post
by aandreari » Thu Dec 10, 2020 3:17 pm
col wrote: ↑Wed Dec 09, 2020 7:08 pm
thanks
Thanks. i'll order one and check, in case when it will arrive can i ask you a couple of things?
aandreari
Post
by aandreari » Mon Jan 11, 2021 12:11 pm
done. calibrated at +12V -12V. fully working. thanks for the idea @col
latigid on
- Ultra Wiggler
Post
by latigid on » Mon Jan 11, 2021 1:23 pm
EATyourGUITAR wrote: ↑Sat Feb 29, 2020 10:40 am
Not sure PLA would cut it if warm electronics are inside... We tried printing PA (nylon) cases but the process is not so easy. Also the time to print on case only makes sense on a one-off basis. In the end we will go for a Hammond case with the PCB adjusted to fit.
col
- Veteran Wiggler
Post
by col » Mon Jan 11, 2021 3:49 pm
aandreari wrote: ↑Mon Jan 11, 2021 12:11 pm
You are welcome! Any photos of your build?
aandreari
Post
by aandreari » Mon Jan 11, 2021 8:28 pm
col wrote: ↑Mon Jan 11, 2021 3:49 pm
Still a beta version, i'll add some kind of rails.
