Unstable DIY R*S Serge NTO
teezdalien
Post by teezdalien » Fri Mar 13, 2020 3:40 am
Hi everyone, I've got a bit of a stability issue that's just cropped up with one of my NTO modules. It's only a couple of years old and has been great up until very recently. I highly doubt it's power related, my case has a good supply and my other NTO and oscillators seem fine.. I've also tried going back through the callibrating procedures and isn't making any difference.
I guess my question is what most likely causing this and is it likely to be an easy fix? What might cause an oscillator to suddenly become unstable in frequency?
cygmu
Re: Unstable DIY R*S Serge NTO
Post by cygmu » Fri Mar 13, 2020 3:57 am
I once had an oscillator whose frequency suddenly went wobbly. The issue in my case was a potentiometer that had somehow gone bad. I think it was the main frequency pot. Replacing it fixed the issue immediately.
Diagnosing might be difficult but if you have a scope and can probe the lugs of the pots you may be able to spot wobbliness.
teezdalien
Post by teezdalien » Fri Mar 13, 2020 4:06 am
Thanks for the advice. I'll dig out my multimeter and go over it thoroughly tomorrow. That actually seems a likely culprit. :tu:
Will report back with my findings.
cygmu
Post by cygmu » Fri Mar 13, 2020 8:45 am
It might be tricky to see much on a meter as opposed to a scope but you should use what you have of course! If the meter has an AC voltage mode, that would let you see how much a given voltage is varying, which is what you want I think.
yghartsyrt
permanent entropy
Post by yghartsyrt » Tue Sep 08, 2020 11:16 am
Did you find the solution? My NTO started to get unstable today. Since I have no scope nor multimeter around, it is hard to check....
teezdalien
Post by teezdalien » Fri Sep 11, 2020 7:36 pm
Sorry for the late response.
It turned out to be a bad potentiometer as cygmu suspected, which was easy enough to address. Ended up buying a whole bunch for spares as I also had some similar problems with other modules. I've read from a few others here having similar wonky NTO issues, so I don't hold great confidence in these particular alpha pots.
yghartsyrt
permanent entropy
Post by yghartsyrt » Mon Sep 14, 2020 1:32 am
cool. thanks.
yghartsyrt
permanent entropy
Post by yghartsyrt » Fri Sep 18, 2020 2:39 am
mine was also a malfunctioning potentiometer
