[IC] General Midi (GM) euro module - any interest?
fitzgreyve
Post by fitzgreyve » Sun Mar 15, 2020 6:32 am
I'm in the early stages of designing a euro general midi module using the SAM2695 datasheet
Ideally I'd go for a yamaha DB50XG, but the are long out of print (so expensive), too big (in euro terms), and consume significant power.
problem with the SAM2695 for DIY is that it's a QFN44 package - problematic to solder by hand, so ideally this needs to be based on a pre-made module
So, I'll probably be going with a euro packaging of the DreamBlaster Synth S2 General MIDI Daughterboard - currently EUR 35.00 plus shipping and vat (which puts it at eur 60.50 shipped to the UK, slightly cheaper chinese version available on ebay!)
probable spec:
- ideally 6HP module (may need to be 8HP if all the options below included)
- L and R out on separate jacks (buffered, with possible output volume control if space allows)
- MIDI in - i tend to use deltron 690 series for midi connectors datasheet
- possible midi in TRS jack if space available
- possible midi thru if space available
- midi input activity led (again, if space allows)
- power: SAM2896 needs about 20ma +5V (derived from +12v), plus a few more mA for buffers etc.
- probably some SMT components (again, a space issue) - but nothing smaller than 0805 and SOIC
- panel black FR4 or black on silver Aluminium.
For clarity, the SAM2695 doesn't need any microprocessor/arduino/rasp-pi to operate, just the normal midi input circuitry, and ideally some audio output buffering.
Is this a "one off", or would anyone else be interested ? panel preferences ?
Under developement:
- "Muse"
https://fitzgreyve2.blogspot.com/
StrangeCaptain
Re: [IC] General Midi (GM) euro module - any interest?
Post by StrangeCaptain » Sun Mar 15, 2020 10:52 am
Noob Q:
do GM have CV/Gate out?
fitzgreyve
Post by fitzgreyve » Sun Mar 15, 2020 11:00 am
No, this is just midi to audio, no cv or gate.
Expert sleepers "General CV" module probably uses the same core DSP IC with CV/gate in - more faciltiies, but not DIY.
Under developement:
- "Muse"
weasel79
Post by weasel79 » Sun Mar 15, 2020 11:56 am
in general i think this is a very interesting idea, but looking at the midi implementation of the sam chip it would kind of a wasted opportunity to not include a little MCU that reads some CVs to alter the sounds.
if you just do midi control only, then why have it in a modular surrounding anyways?
generalizing, i think there's a ton of untapped potential in (ab)using general midi rompler chips, but you will only generate siginificant interest if you do something extraordinary with it.
forestcaver
Post by forestcaver » Sun Mar 15, 2020 12:08 pm
Looks intersting and fun
My thoughts:
If midi in, audio out, no cv, then why eurorack? Eurorack hp and power is expensive!
The board you linked is really expensive compared to the chip and doesnt look like it adds any real functionality - unless I am missing something?
QFN is not that hard to hand solder (done quite a lot of them by hand and I’m not very skilled...)
Looks like it could be a fun,cheap, standalone synth... ???? Nice idea....
ixtern
Post by ixtern » Mon Mar 16, 2020 7:29 am
I have a working prototype of such module (GM/GS) with much better DreamBlaster_X2 and Arduino Mega Mini controller.
My module can be directly controlled from the MIDI keyboard or sequencer, 16-channel 81 voices polyphony, may have loaded different sound banks (although there are not so many coz it's proprietary format), and has controlled by encoders/MIDI some parameters for every channel, like Attack/Decay/Release, Reverb time, Filter Resonance.
ArduinoSequencer.pdf
resynthesize
Post by resynthesize » Mon Mar 16, 2020 10:57 am
interested, but agree with other posters that providing some level of CV/gate control would make this a lot more fun.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Mar 16, 2020 11:41 am
do you have a hand held hot air reflow station? you really don't want to spend $35 on that PCB. you can get the hot air machine for $60.
av500
Post by av500 » Tue Mar 17, 2020 6:04 am
I designed a Eurorack "MIDI" module a few years back using the VS1053B chip. I put MIDI in quotes since it does not have MIDI-in, who needs MIDI in Eurorack anyway ;)
instead you control the General MIDI instrument or drum voice using pots and CVs and V/oct and gate, since the chip is polyphonic you can layer several instruments on top of each other, tuning them all using pitch bend or spreading them octaves apart. if you "sort" the GM instruments a bit you can get some smooth blends between voicings. and of course you can get mayhem with random CVs :)
When ES came out with "General CV" I basically shelved it.
here is a video and a soundcloud snippet, I can post some pics tonight...
S0210
Post by S0210 » Fri Apr 10, 2020 10:18 am
What about a 3U 16HP module?
Actually Serge (from DreamBlaster) is consideting a new Eurorack module. (Not this one.) Reaching out to him for technical advices could be a good idea.
