ELMYRA
swish
ELMYRA
Post by swish » Sun Mar 22, 2020 3:46 pm
Just saw this on elektronauts forum...
https://neutral-labs.com/elmyra/
Flounderguts
Re: ELMYRA
Post by Flounderguts » Sun Mar 22, 2020 4:13 pm
This looks fun.
Maybe I'll do one on some of the useless stripboard I have kicking around.
Flounderguts
EATyourGUITAR
has no life
Re: ELMYRA
Post by EATyourGUITAR » Mon Mar 23, 2020 7:53 am
thanks for sharing this
neutral-labs
Re: ELMYRA
Post by neutral-labs » Thu Mar 26, 2020 4:14 am
Hi, I made this ^^. If anyone has any questions about the build (or a need for PCB, panel or kit), let me know.
If you do, maybe you could share a stripboard layout? I could include it on my project page.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Apr 04, 2020 5:48 am
Firmware v1.2 now has chromatic mode and a polyphonic sequencer. ;)
EATyourGUITAR
has no life
Re: ELMYRA
Post by EATyourGUITAR » Sat Apr 04, 2020 9:29 am
sounds AMAZING!
tele_player
Re: ELMYRA
Post by tele_player » Sat Apr 04, 2020 11:25 am
I want one.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Apr 04, 2020 3:54 pm
Kit or built? Drop me a message at admin@neutral-labs.com along with your location if you're interested. And of course you can also go full DIY, all the info is there: https://neutral-labs.com/elmyra/
skautkurt
Re: ELMYRA
Post by skautkurt » Thu Apr 09, 2020 10:17 am
Just received my Panel and PCB today, they are gorgeous. Just need to wait for the parts now.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Fri Apr 10, 2020 3:25 am
To everyone else who has ordered: Shipping within Germany is no problem, but DHL currently refuses any shipments abroad due to corona. I'm looking for other options that still work.
In the meantime, here's some front panel porn:
EASYBOY
Re: ELMYRA
Post by EASYBOY » Sat Apr 11, 2020 2:03 am
How "hard" of a build is it? I am very inexperienced. Does it habe SMD components on it?
Greetings from Cologne!
tele_player
Re: ELMYRA
Post by tele_player » Sat Apr 11, 2020 8:55 am
No SMD.
Read this a few times:
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Apr 11, 2020 9:16 am
Well, technically the microcontroller board has SMD parts, but those are already done. ;)
So it's quite easy.
tele_player
Re: ELMYRA
Post by tele_player » Sat Apr 11, 2020 11:45 am
Easy, but panel wiring can be a cause for newbie confusion.
selfdestroyer
Re: ELMYRA
Post by selfdestroyer » Sun Apr 12, 2020 4:51 pm
I'm looking at starting one of these. What did you use for the touch pads? They look nice and solid.
My DIY / Music Blog They Remain Silent
neutral-labs
Re: ELMYRA
Post by neutral-labs » Mon Apr 13, 2020 4:11 pm
The white prototype has a type of glass frame fitting, but it's not ideal. For the black one (as well as for my kits and builds) I'm using the same screws that the Lyra has, only larger.
selfdestroyer
Re: ELMYRA
Post by selfdestroyer » Mon Apr 13, 2020 10:02 pm
Thanks, I had no idea they were just thumbscrews. This makes is easier to track down for me. Thanks!
Flounderguts
Re: ELMYRA
Post by Flounderguts » Mon Apr 13, 2020 10:43 pm
The front panels are from PCB stock, no?
Why not do ENIG touchpads on the PCB panel? I like the big thumbscrews, but touch panels are fun, too!
Flounderguts
neutral-labs
Re: ELMYRA
Post by neutral-labs » Tue Apr 14, 2020 2:33 am
Yes, these are FR4 panels. I was thinking about embedded touch sensors like e.g. Make Noise René, but in the end decided against it. I think the bigger surface area of the metal plates gives you more control. I also like the haptics of it more.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat May 02, 2020 5:58 am
Here I'm testing a few builds together with a DFAM:
woodster
Re: ELMYRA
Post by woodster » Fri May 08, 2020 1:06 pm
What USB connectors would be the most durable solution to use in peoples opinion ?
Looking for something that is able to be securely screwed into the enclosure, as opposed to just using a dangling cable.
It's the last missing piece of the jigsaw.
skautkurt
Re: ELMYRA
Post by skautkurt » Fri May 08, 2020 3:08 pm
I think USB B is quite the strong connector, and also quite easy to find cables for. And there are a ton of connectors you can screw onto the case.
https://www.aliexpress.com/i/32828469710.html
wery67564
Re: ELMYRA
Post by wery67564 » Fri May 08, 2020 11:32 pm
Anyone know of a good enclosure solution in the states? Got my kit today, but the recommended box is only in DE...
tele_player
Re: ELMYRA
Post by tele_player » Sat May 09, 2020 1:07 am
I’ve got a bamboo box from Amazon, 6x9x2.5. I just measured, and it might be a bit small for the panel... I’ll know when the kit arrives. I was hoping the difference between US and German Amazon would be units of measurement.
drox
Re: ELMYRA
Post by drox » Sun May 10, 2020 7:39 pm
these look awesome. going to add this to my to do list. I know it's maybe not the point and it's great how it is already but would some sort of sequencer sync option be a possibility in the future?
