ELMYRA
Flounderguts
Re: ELMYRA
Post by Flounderguts » Sun May 10, 2020 11:43 pm
tele_player wrote:
Sat May 09, 2020 1:07 am
I’ve got a bamboo box from Amazon, 6x9x2.5. I just measured, and it might be a bit small for the panel... I’ll know when the kit arrives. I was hoping the difference between US and German Amazon would be units of measurement.
I got a set off Amazon from mDesign Inc. 2 boxes for about $15. They stack, so there is an inset around it. The inset measures 221mm x 144 mm, with ledges 4mm wide, so the panel will fit.
Flounderguts
wery67564
Re: ELMYRA
Post by wery67564 » Mon May 11, 2020 9:20 am
Do you have a link?
Flounderguts
Re: ELMYRA
Post by Flounderguts » Mon May 11, 2020 2:02 pm
mDesign Bamboo Kitchen Cabinet...
9x6x2.5...there are several sizes
Flounderguts
tele_player
Re: ELMYRA
Post by tele_player » Mon May 11, 2020 8:00 pm
I’m using the 6x9 as a tiny EuroRack case. Powered by synthrotek USB Power, currently has a Plaits clone and a Vortex Generator. About 22Hp left for more modules.
wery67564
Re: ELMYRA
Post by wery67564 » Mon May 11, 2020 8:29 pm
I think I am just gonna draft up a custom acrylic case I think, will share how that turns out here when it is all said and done...
neutral-labs
Re: ELMYRA
Post by neutral-labs » Wed May 13, 2020 6:50 am
I don't use a USB connector for powering my builds, but a DC barrel connector instead. These are round jacks, so it's much easier to drill a hole in the case. USB B jack hole must be chiseled or routed. ;)
You can easily get USB A to barrel plug cables on Ebay or really anywhere. You'll have to open the case for a firmware update, but that's just 4 screws. Also, the new version doesn't even use the micro USB port for powering the circuit, so it remains unconnected.
As for sequencer sync, I've had many requests for it and am thinking about incorporating it in the future. Unfortunately there are no more free input pins on the microcontroller board.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Wed May 13, 2020 6:51 am
By the way, there is now also a PDF manual.
woodster
Re: ELMYRA
Post by woodster » Wed May 13, 2020 6:56 am
Yeah, I've opted to build a little breadboard power board, so can run it off a 9v Pedal PSU and use a std barrel connector.
Bodo1967
Re: ELMYRA
Post by Bodo1967 » Thu May 14, 2020 8:21 am
I made a rectangular hole in my DIY case and used one of these:
This allows me uploading possible firmware updates without having to open the case.
I cut the cable and soldered it back together, integrating the power switch and reconnecting the green and white USB data wires.
The PCB is held by four small pieces of wood with a notch I made:
This is my Elmyra - LED sockets are still missing, but it's fully working and sounding awesome. And I also finished my PedalPCB "Spatialist" reverb build last Sunday - goes along great with the Elmyra.
Woo-hoo :bananaguitar: !
... why buy it for $100 when you can build it yourself for $150?
woodster
Re: ELMYRA
Post by woodster » Thu May 14, 2020 8:25 am
I like your PCB mounting solution, might have to pinch that idea!
I just need to drill the 4x holes to mount the panel to the wooden box, hopefully I don't balls that up :lol:
Bodo1967
Re: ELMYRA
Post by Bodo1967 » Thu May 14, 2020 8:43 am
I attached small pieces of adhesive insulation tape (similar to this) onto the panel preventing I'd slide away with the drill or scratch the panel :D. The panel material was easy to drill.
Addam
Re: ELMYRA
Post by Addam » Thu May 14, 2020 12:48 pm
Sorry to take this off topic a little, but eurorack modules are not slightly too short height-wise to fit in these bamboo boxes? Are you able to just drill and screw them right in? This is very interesting.
Edit: thanks for the reply below!
tele_player
Re: ELMYRA
Post by tele_player » Thu May 14, 2020 2:54 pm
I added two 1/2" wooden rails.
Basterdman
Re: ELMYRA
Post by Basterdman » Fri May 29, 2020 9:04 pm
So much want. this will be my next build for sure.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Fri Jun 19, 2020 10:04 am
A collection of sound snippets I made with 2 Elmyras and various pieces of gear (0-coast, Lyra-8, Digitakt, Analog Four, Ocean Machine, GR-1, Eurorack etc.).
Also, those kits are now officially available from the friendly guys at Exploding Shed (EU shipping only): https://www.exploding-shed.com/diy-kits ... utral-labs
If you're anywhere else, you can of course order them directly from me.
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Sep 05, 2020 6:25 am
Coming back to this since there haven't been any updates for a while: The new PCB that has been available for some time now makes it so much easier to build than the old one that Bodo shows in his post above (props to him and the other early adopters though). The new version has the knobs and switches mounted directly on the PCB, so you don't need to run a bazillion wires between panel and PCB.
You can see the new v1.3 kit in this unboxing video by Elk Elektronik (He will also run a build workshop soon in AUS, so contact him if you're in the area and interested):
In the meantime, I made a nice little promo vid:
And I'm quite proud to announce that assembled Elmyras are now available at Perfect Circuit (the black version is currently on sale!): https://www.perfectcircuit.com/neutral-labs
Kits are still available through me and soon SynthCube will have them in stock too.
HZR
Re: ELMYRA
Post by HZR » Mon Sep 07, 2020 11:03 am
I just made a dc to usb cable off the other half of the usb cable i used for powering the teensy.
Now i can plug it into my doepfer usb module and it will hopefully works^^
neutral-labs
Re: ELMYRA
Post by neutral-labs » Mon Sep 07, 2020 11:09 am
So you created the first Elmyra Eurorack mod. Congratulations!
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sun Oct 11, 2020 2:10 pm
Elmyra goes really well with this lovely pedal. :slight_smile:
Also, kits are now finally available at a US retailer (SynthCube): https://synthcube.com/cart/makers/neutral-labs
Other purchase options are listed on the site: https://neutral-labs.com/elmyra
Flounderguts
Re: ELMYRA
Post by Flounderguts » Sat Oct 17, 2020 12:52 pm
Are the switches ON-ON (102), or ON-OFF-ON (103)?
Flounderguts
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Oct 17, 2020 1:01 pm
All of them are on-on.
Flounderguts
Re: ELMYRA
Post by Flounderguts » Sat Oct 17, 2020 1:22 pm
:tu: :sb: :goo: :party:
Flounderguts
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sat Oct 17, 2020 1:29 pm
And Thonk has the kits in stock now too: https://www.thonk.co.uk/shop/elmyra/
:headbang:
Flounderguts
Re: ELMYRA
Post by Flounderguts » Sun Oct 18, 2020 3:30 pm
I have a 2u space in my rack, and I'm doing a stripboard version x2 to fill up the space (and to use up the Itsy Bitsy boards I have around for some reason)
I found the schematic posted on the Neutral Labs website a bit hard to parse, so I threw together my own. @neutral-labs, is it ok to post it here?
Flounderguts
neutral-labs
Re: ELMYRA
Post by neutral-labs » Sun Oct 18, 2020 3:32 pm
Sure, go ahead.
