Need to find a certain potentiometer...
Flounderguts
Post by Flounderguts » Mon Mar 23, 2020 12:34 pm
Anyone ever seen a panel mount version of this?
Hoping to find B50K, B500K, B750K, and B5M
Flounderguts
selfdestroyer
Re: Need to find a certain potentiometer...
Post by selfdestroyer » Mon Mar 23, 2020 1:47 pm
I have never seen the tall plastic trimmers with a nut.. your best bet is the T-18 pot from Thonk with the micro knobs.
https://www.thonk.co.uk/shop/alpha-9mm- ... tical-t18/
https://www.thonk.co.uk/shop/micro-knobs/
My DIY / Music Blog They Remain Silent
guest
Post by guest » Mon Mar 23, 2020 1:57 pm
never seen them either, these are the closest ive seen:
https://www.mouser.com/ProductDetail/?q ... nHiQ%3D%3D
they do make them, though, but it would probably be a special order. might be easier to just make a small pcb that can fasten to the front panel.
openmusiclabs.com
devinw1
Post by devinw1 » Mon Mar 23, 2020 2:56 pm
Panel mount, no, but yeah most of the pot makers (Alpha, etc..) will make their plastic shaft pots with or without the threaded bushing (like the example in guest's link). You can always solder wires to the solder legs and use it as a panel mount pot though.
KSS
Post by KSS » Mon Mar 23, 2020 8:58 pm
Not with a nut. But Song Huei do make a 9mm shaft knob pot with an extended bushing AKA collar which, when used with an appropriate hole in the panel, serves to support the pot shaft nearly all the way to the panel's top surface. In practice with good design and assembly standards, this does in fact come close to the feel of a pot with panel nut.
The panel lut extends farther up the pot shaft, so mere geometry means the collar cannot be equal to the nut. But that's less about the nut than the geometry.
P/N R0903N Described as Vertical type. Single unit with collar.
The only reason we don't see these more often is that poor practice in board populating and assembly makes the collar a liability instead of an asset. If one assembles the panel to PCB before soldering the pots -and if the PCB has enough pad hole compliance to allow pots shifting to accomodate the panel, the collars are a great improvement in this style use. Pots constrained by snug panel holes rather than pots constrained by PCB and tolerances accomodated with enlarged panel holes.
edit: note that this pot is available with the knob-style shaft. The drawing shows the D-shaft, but T18 and others are available too. /edit
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Mar 24, 2020 1:50 am
order 10,000 units. probably super cheap too. you could keep 100 and sell the other 9900 to thonk or pusherman
Flounderguts
Post by Flounderguts » Wed Mar 25, 2020 7:15 pm
Don't think I haven't considered it! If I thought people would want the weird stuff *I* want, I'd stock up on funky hard-to-find parts and sell them on a website.
Like the rgb tact switches that 4MS uses, this type of tall pot, and 1p8t panel mount slide switches with tall slides! Or beautiful, smooth joysticks with swappable potentiometers and 3 axis control. And tall thumbwheel pots in audio grades. The list goes on...
Flounderguts
KSS
Post by KSS » Wed Mar 25, 2020 8:41 pm
Erthenvar closing has left a definite hole in the marketplace. One of the things they sold were these tall shaft knob pots . Not the collar kind. And jacks and nuts. They did tiles too, but you ouldn;t have to have those.
At any rate, this hole will fill over time as someone or many step in. The time is ripe for a west coast USA Erthenvar replacement. East coast might work too, but Synthcube is already there.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Thu Mar 26, 2020 10:31 pm
I tried to buy him. I sent a proposal asking for the price and the valuation of the company. got no reply. he makes ecigs for his employer. he is no longer self employed. his mom also worked for him. pulp logic was a partner in the early days of earthenvar. without pulp or nick, it would just be mom. you can't expect her to do all the work.
