voltage controlled slew / portamento circuit
ESSY
Post by ESSY » Tue Mar 24, 2020 10:15 am
So I have been using this slew circuit found in this thread by Harry Bissel for the module I am designing and it works great - does the job - low part count - simple! However... I can't help but want to add CV control to this circuit. After researching a bunch it seems the best way to do this is to use a vactrol. :despair:
So I went ahead and hooled up a vactrol in series with the potentiometer and it gave me my VC Slew, however, I learned there are some caveats to this approach. One is that the raw vactrol will output a resistance between 0 ohms and 10 Mohms, which is not ideal for tuning in a nice max/min slew amount. Second, the vactor cannot be attenuated with the existing potentiometer, which would be a real nice thing to have.
So poking around a bit more I found a circuit on this thread which shows how to keep the output resistance of the vactrol within a range using a "limiting resistor". Works like a charm.
Final tested circuit came out like this:
Now I really lack expertise when it comes to circuitry so I wanted to ask the forum this question:
Is there a more ideal solution out there that doesn't involve using a vactrol / H11F1?
guest
Re: voltage controlled slew / pornomento circuit
Post by guest » Tue Mar 24, 2020 11:00 am
you can also use an LM13700 or SSM2164.
openmusiclabs.com
ESSY
Post by ESSY » Tue Mar 24, 2020 11:29 am
theres also this article suggesting I can do it with a JFET transistor?
The LM13700 or SSM2164's are a bit overkill as I I only need 1 vs 4
electricanada
Post by electricanada » Tue Mar 24, 2020 11:31 am
Came for the pornomento; left disappointed.
elektrouwe
Post by elektrouwe » Tue Mar 24, 2020 11:32 am
... I learned there are some caveats to this approach. One is that the raw vactrol will output a resistance between 0 ohms and 10 Mohms, which is not ideal for tuning in a nice max/min slew amount. Second, the vactor cannot be attenuated with the existing potentiometer, which would be a real nice thing to have.
your transistor control acts more like a switch, not as a linear control. Better use an opamp + transistor as voltage contolled current source for the vactrol LED with 3 summing inputs: 1 for ext. CV, 1 for CV-potentiometer, and 1 for CV-trimmer to adjust operating point.
Potentiometer is no longer in signal path then
jorg
Post by jorg » Tue Mar 24, 2020 11:33 am
I should devise a circuit to upgrade my portamento to pornomento. That would be so fun.
elektrouwe
Post by elektrouwe » Tue Mar 24, 2020 11:34 am
say "hello" to Mr. Freud !
ESSY
Re: voltage controlled slew / portamento circuit
Post by ESSY » Tue Mar 24, 2020 11:47 am
ahah pornomento :doh: edited out
ESSY
Post by ESSY » Tue Mar 24, 2020 11:51 am
The thing with this is I kinda like being able to attenuate the external CV signal with the potentiometer, and the way I have it now I kinda get the best of both worlds. When no CV is present, the potentiometer will still adjust the amount of slew
guest
Post by guest » Tue Mar 24, 2020 12:16 pm
an LM13700 is pretty cheap and easy to work with. it will also give consistent results, and you can make a dual slew rate limiter! it also allows for various contours on the slew. or you can use the other half for a S/H, VCA, VCO, etc.
openmusiclabs.com
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Mar 25, 2020 3:55 pm
if you put the vactrol in series to C3 and increase C3 to 100uF that should get you down to 0 slew. then you can put the pot on the driver circuit with a normal connection in the jack for when nothing is inserted. you can also set it up as a input attenuator normalled to a 5v DC offset. I expect a vactrol to get down to 10K. I never design a circuit where I expect the Ron to be < 10K ohms even if one vactrol can do it. vactrols vary a lot.
this entire circuit is inferior to the discrete four transistor VC slew used by buchla, serge. that will get you to 0 slew or 60 seconds.
ESSY
Post by ESSY » Fri Mar 27, 2020 9:01 am
Do you think you can link to a schematic here? Is it this one? I would like to take a look. One thing to note about the op circuit is I need to insert 4 of them into a single module. So at some point part count as well as PCB space needs to be considered
guest
Post by guest » Fri Mar 27, 2020 9:20 am
either the vactrol or 13700 circuit would be the easiest, in particular if you want a lot of them. the 13700 version is 1/2 of a 13700, an opamp, and a transistor per channel.
openmusiclabs.com
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Mar 27, 2020 9:39 am
I was thinking this http://www.synthpanel.com/modules/cgs775_vcs.html
it requires an LM3900 with 5 transistors. however, if you understand how the circuit works, that 4 transistor core is basically the entire circuit. everything else can be chopped off and replaced with a very minimalist support circuitry. the serge VCS, the buchla 281, make noise maths, MOTM 820, befaco slew, befaco rampage all have that 4 transistor slew core with different supporting circuitry. where would we be without it?
here is a more minimalist example https://befaco.org/docs/Slew_Limiter/Sl ... ematic.pdf
ESSY
Post by ESSY » Sat Mar 28, 2020 8:12 am
ahh this was honestly the first schematic I looked at when I was first trying to figure this out! I have NO idea what is going on in this circuit, but I will try and study up on transistors because it would sure be nice to understand how that famous slew circuit works
ESSY
Post by ESSY » Sat Mar 28, 2020 8:13 am
I am also going to wire this up today and see what I get. It has been mentioned/recommended so many times I gotta see what its all about
mush
Post by mush » Sat Mar 28, 2020 9:47 am
This link might be of help to you as it explains the pair of differential transistor pairs in a quite simple way. (it's almost the same integrator in befaco's slew limiter as in the serge vcs, dusg, etc.)
http://www.timstinchcombe.co.uk/index.php?pge=vcs
In for weird music, nice pictures and retro videos? Follow me at Instagram: https://www.instagram.com/cphmush/
