DIY Peaks Calibration Method? (Not Present Online)
gamblid
Post by gamblid » Tue Mar 24, 2020 6:44 pm
I have a diy peaks from blue lantern i just finished but can't seem to find anywhere online how to calibrate it. This is the only vague thing i found online:
To enter calibration mode, power the module on with the second button pressed. The first and second knobs (third and fourth) act as coarse/fine adjustments for offset on channel 1 (channel 2).
Ok... there is the following buttons: Split, Mode, Trig 1 and Trig 2. Is it talking about trig 2?
but what am I supposed to do after that? what do i press to save calibration?
It seems the calibration method was either removed or never added to the official Mutable Instruments website
Agawell
Re: DIY Peaks Calibration Method? (Not Present Online)
Post by Agawell » Wed Mar 25, 2020 5:14 am
The answer to the question is in the question
adjust the pots so you get 0 offset on the outputs
forestcaver
Post by forestcaver » Wed Mar 25, 2020 5:57 am
Be aware that you’ll only be able to enter calibration if you have a hacked bootloader or a bootloader compiled from code that was relatively recently released (jan 2019) - or use a factory peaks....
