BCY87 Question
Alfrede
BCY87 Question
Post by Alfrede » Wed Mar 25, 2020 12:35 pm
Hi Dudes,
i have a question can i use this Dual NPN Transistor for making a module?
BCY87 Datasheet
I found at googeling that a person from russia should take it for an replacement for an LM394.
So have you any ideas what i can do with this Part?
Alfrede
EATyourGUITAR
has no life
Re: BCY87 Question
Post by EATyourGUITAR » Wed Mar 25, 2020 3:42 pm
broken link. try this
http://pdf.datasheetcatalog.com/datashe ... /BCY89.pdf
The BCY87 and BCY88 are intended for use in pre-stages of differential amplifiers where low offset, lowdrift and low noise are of prime importance
I am not an expert in exponential converters but it looks like +/-%10 HFE from T1 to T2. I think we can trim that out on the 1v/oct calibration. the deltaV/deltaT is excellent. the deltaI/deltaT is also excellent. max uV/K = 3 and max uI/K = 0.5
Alfrede
Re: BCY87 Question
Post by Alfrede » Fri Mar 27, 2020 1:36 am
Okay thank you for your first look. What would you do with it when you have them?
jorg
Re: BCY87 Question
Post by jorg » Fri Mar 27, 2020 9:22 am
You could also use BCM847; it's cheap, plentiful, and works nicely for expo converters, ladder filters, diff amps, etc.
https://assets.nexperia.com/documents/d ... _BS_DS.pdf
BCM847 is SMT; don't know whether that's a problem for you. BCM847BV grade has Vbe matching to 2mV, compared to 3mV for BCY87 (or 6mV for BCY88). hfe matching is the same for BCM847 and BCY87; BCY88 is slightly worse.
BCM847 is much faster (100MHz vs 10MHz). BCM847 is lower noise (NF=2.8dB vs 4dB). Voltage and power limits are about the same; though BCM847 handles slightly higher power. DC gain is more tightly controlled toward the high end (200-450 for BCM847 vs 100-450 for BCY87).
EATyourGUITAR
has no life
Re: BCY87 Question
Post by EATyourGUITAR » Fri Mar 27, 2020 10:10 am
I think it is obvious that it will be a VCO but it could also be a VCF with 1v/oct pitch tracking exactly the same exponential converter as the VCO.
