Yarns question (Yeezus PCB)
ashley27
Post by ashley27 » Fri May 22, 2020 7:18 am
Does anybody know what pot to use for the Edit knob, SW1. I can't find this out anywhere. Thanks
cnicht
Re: Yarns question (Yeezus PCB)
Post by cnicht » Fri May 22, 2020 7:36 am
It's an encoder.
Have a look at the Yarns BOM.
ashley27
Post by ashley27 » Fri May 22, 2020 8:03 am
adam
Post by adam » Fri May 22, 2020 8:18 am
it's not in the boms, you can get them on ebay etc
ashley27
Post by ashley27 » Fri May 22, 2020 8:35 am
OK thanks. How can I find out what it is I need to buy then?
ashley27
Post by ashley27 » Fri May 22, 2020 8:41 am
cnicht
Post by cnicht » Fri May 22, 2020 2:14 pm
It's described in the MI BOM (SW1) but it isn't referenced with a manufacturer's number.
The important thing is to have enough of the threaded collar of the encoder protruding through the front panel to attach a nut after you've mounted the other components which protrude through the front panel.
ashley27
Post by ashley27 » Fri May 22, 2020 2:43 pm
I don’t know anything about encoders is the problem, other than there are both 12 and 24 positions to choose from
cnicht
Post by cnicht » Fri May 22, 2020 3:11 pm
The MI BOM specifies 24 pulses per revolution with a push switch.
You should be ok with 12 pulses, you'll just need to turn it more to change values.
noobyist
Post by noobyist » Fri May 22, 2020 3:13 pm
MI modules often use PEC11R-4220F-S24 encoders. But Yarns can be tricky because the DIN jacks are very tall. You may have to solder the 3 switches and the encoders a little bit above the PCB after mounting everything on the panel, as indicated by cnicht.
ashley27
Post by ashley27 » Sat May 23, 2020 1:14 am
Thanks all
