Quad white and colored noise source. Quad random voltage source
Haralds:Werk
Post by Haralds:Werk » Wed Jun 24, 2020 5:30 am
It is quite useful to have different adjustable noise and random voltage sources. Depending on your patch stile of course. Here is the quad version of my noise module from the NGF project. It is a combination of two original Elektor Formant modules. The noise module from Elektor Formant book one and the colored noise (CNC) module from book two. It provides four independent white noise outputs, four adjustable colored noise outputs with "red" "blue" adjustment. The four random voltage outputs are adjustable in speed of change. The noise is derived from the reverse biased BE diode of an NPN transistor.
Specs and features
• Four independent white noise outputs
• Four independent adjustable colored noise outputs with "red" "blue" adjustment
• Four random voltage outputs, adjustable in speed of change
• Four LED indicating the random voltage change
• Runs on +/-12V and +/-15V
• Power consumption around 65mA each rail
The documentation and the Gerber files for download can be found in my website.
www.haraldswerk.de
Home of Next Generation Formant
dot matrix madness
Re: Quad white and colored noise source. Quad random voltage source
Post by dot matrix madness » Wed Jun 24, 2020 6:32 am
Any recommendation, which transistors to consider as candidates in the noise source? BC547C, 2N3904
Licenced to solder since 1993
jorg
Post by jorg » Wed Jun 24, 2020 9:50 am
Separate (non-correlated) noise junctions?
Haralds:Werk
Post by Haralds:Werk » Wed Jun 24, 2020 1:14 pm
No, I randomly picked up four BC550C. One of them was a bit at the weak side, but this is easily compensated with increasing the amplification.
www.haraldswerk.de
Haralds:Werk
Post by Haralds:Werk » Wed Jun 24, 2020 1:15 pm
Yes, four independent noise sources.
www.haraldswerk.de
EATyourGUITAR
has no life
Post by EATyourGUITAR » Thu Jun 25, 2020 12:55 pm
A noise bridge circuits clips in the transistor. If you always use noise bridge circuits in parallel, they should be pretty close in amplitude. There is enough gain that you could use anything as a noise source at the input of the noise bridge.
I took a look at the schematic. It looks like it already has enough gain. You can give it more gain by adjusting resistor values. You could add a single transistor to amplify the noise source. You would need to cut one trace per channel. You would need to mount 4 transistors 8 resistors. Probably just change the 10K into 2M. 5K should work better.
