How can I find L brackets sized for M3 screws ?
goldplate
Post by goldplate » Fri Jun 26, 2020 5:05 am
How do you call them ? :hmm:
I need to mount some PCBs at 90 degrees of a panel. Ideally I would need one angle of the bracket with a "stretched" hole so I can adjust its position regarding the holes placement on the PCB.
Paradigm X
Re: How can I find L brackets sized for M3 screws ?
Post by Paradigm X » Fri Jun 26, 2020 5:45 am
Soundtronics do something like this;
https://www.soundtronics.co.uk/synth-mo ... -brackets/
Almost certainly generic cheaper versions, but Im not sure about types etc (i hate this side of DIY!)
goldplate
Post by goldplate » Fri Jun 26, 2020 6:10 am
Thanks !
Those ones seem to be exactly what I'm looking for (except not M3, but that may still fit).
I thought it was a pretty common product but it seems not...
Paradigm X
Post by Paradigm X » Fri Jun 26, 2020 6:31 am
cool. the panels they sell actually have a threaded hole so you dont need to have a hole in the front plate, but theyre 5u motm size only, dont know if thats any good to you.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jun 26, 2020 10:26 am
talk to a sheet metal shop about aluminum. the squares can be punched out quickly. bending many sheets to the same 90 bend is easy at a shop that has those tools. you can get these down to $1 in short run or $0.80 in bulk.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jun 26, 2020 10:34 am
Rex Coil 7
Post by Rex Coil 7 » Fri Jun 26, 2020 10:37 am
A length of angle aluminum (1x1" or 1.5 x 1.5"), cut into a few short lengths, drill a few holes. Done.
$10 bucks or so for a three foot length of angle aluminum ... enough there to make at least thirty six brackets. You need access to a hacksaw, a vise, a flat file to dress edges, and a drill/drill bits.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jun 26, 2020 3:01 pm
if you are going to drill aluminum you should have one of these. do not use it on steel. wood and alu only.
https://www.riogrande.com/product/del-r ... nch/118117
Grumble
Post by Grumble » Fri Jun 26, 2020 3:34 pm
1722744.pdf
I use these a lot
lm13700
Post by lm13700 » Sat Jun 27, 2020 1:52 am
Keystone 612 Mounting Bracket, there not M3 though, but just change the screw. keystone makes other 600 series.
Altitude909
Post by Altitude909 » Sat Jun 27, 2020 6:51 am
If you need it for a one time thing, front panel express has theirs (6.5mm from edge to center of hole, M3)
page 12: https://www.frontpanelexpress.com/downl ... sembly.pdf
If you're in the US, its not going to be easy finding M3 hardware, consider going down to 4-40 and then you will have all sorts of options (mouser has a good selection). Otherwise, Ettinger is the place for metric hardware, you can get it through Newark but they have to get it from the UK so there is a flat processing fee
https://www.ettinger.de/en/product/sear ... ART=WINKEL
Altitude909
Post by Altitude909 » Sat Jun 27, 2020 7:28 am
