Question about CGS gate to trigger [SOLVED]
batchas
Post by batchas » Mon Jun 29, 2020 5:11 am
If I emulate quickly the CGS gate to trigger circuit. I see a negative signal at the output.
Is it the emulation that does something weird (maybe because of the opAmp as I can't define it as LM358 or LM324) or(more likely) me doing something wrong?
EDIT: added "EDIT: solved." in this post and forgot to add it in the title. Then edited again to change the title :)
Batchas website
Bandcamp page
batchas
Re: Question about CGS gate to trigger
Ooops. Double post.
Batchas website
Bandcamp page
Chaotic
Post by Chaotic » Mon Jun 29, 2020 5:45 am
You have drawn it wrong
dot matrix madness
Post by dot matrix madness » Mon Jun 29, 2020 6:47 am
The resistors around the positive and negative input are drawn wrong. The kind of OpAmp doesn't play a role
in the simulation. However, in real life the "slow" LM358 is preferred over faster one, because it doesn't
get into self oscillation.
Licenced to solder since 1993
batchas
Post by batchas » Mon Jun 29, 2020 1:13 pm
Awesome. Thank for your help.
I'll look at the resistors again tomorrow then, cause right now I don't see my error. Need to take some distance!
Batchas website
Bandcamp page
Repeater
Phantom Powers
Post by Repeater » Mon Jun 29, 2020 2:18 pm
Another thing to check once you've fixed the connection of that voltage divider is how you've powered your opamp. Ken's circuit is single supply with a LM358 and the negative rail is not used. Can't speak to your simulation, but in real life a TL072 for example will not give the same performance as a LM358 in this application.
batchas
Post by batchas » Tue Jun 30, 2020 12:22 am
Just woke up and had a look at what I did. OBVIOUS. HA!
Yesterday I was incapable of seeing it, though it was completely wrong!!! I even forgot the 100k resistor.
Scary...
Anyway, as usual always good to have a break when you don't see see what is wrong, instead of insisting.
It's so simple, I should have draw it on paper and breadboard it instead. Way quicker and keeps me away from the monitor which does not do me good at all.
Again thanx a lot for all answers! Very helpful :tu: :tu: :tu:
Batchas website
Bandcamp page
