Teensy 3.2 in uO_C - Phyically damaged LED = Problems?
Overand
Post by Overand » Tue Jun 30, 2020 9:51 am
EDIT- I'll order a replacement Teensy, for the whole ~$24 USD, too - just hoping to be up and running sooner! And, fixing things is nice.
Folks - I was doing some work on a uO_C (replacing the pin headers on the Teensy 3.2, as part of switching teensy modules between two uO_C modules - a whole different story).
So, there's an LED on the teensy, near the button. From what I can tell on the uO_C schematic and the Teensy 3.2 schematic, this LED is related to the clock on U2, a DAC on the uO_C.
Regardless, this O&C now boots "sometimes." Often it will hang/black screen. The LED is definitely not working, because it's cracked/broken. Does that likely have an effect other than cosmetic? There certainly could be other damage or issues, but, that's all I've seen so far.
Should I try to shoehorn a non-SMD diode there temporarily to test? Etc?
Sites: overand.com | SoundCloud | YouTube ModularGrid: MOTM | Euro
WTB: MOTM Case, Euro VCAs, Sequencers, Env Followers & Interfaces.
Building the modular since ~2003
Altitude909
Re: Teensy 3.2 in uO_C - Phyically damaged LED = Problems?
Post by Altitude909 » Tue Jun 30, 2020 12:49 pm
none whatsoever, just a programmable indicator
emmaker
Post by emmaker » Tue Jun 30, 2020 1:33 pm
Have you changed power supply or added new modules to your synth?
According to the uO&C thread on Muffs some have issues with the power supply causing the Teensy not to run properly. A reset supervisor chip was added to handle this. Search for that thread and see if that maybe your problem.
Phitar
Post by Phitar » Wed Jul 01, 2020 8:47 pm
:tu: Agree. Question is.... Is that all you messed up? :despair:
When in doubt...Swap it out!
Hopefully it's in a socket. I just had to change one out last week that was soldered on. What a PITA THAT was! :bang:
Waiting for the electrician... or someone like him. - Firesign
