Hi All...
If you've followed the Lyra-8 DIY thread at all, you'll know that I've been working on a set of PCBs that incorporate all of Vlad's "tweaks."
I've started a webstore at flundrton.com to provide this stuff. As of today (Feb 2) the first batch of wings are sold out, lots of 2nd gen wings are in stock. As well as the integrated expanded panel, the standard size panels (266x266mm) are back, with a 2nd version with a mandala-style touchpad for those who don't like/can't find the DIN screws. I also have a small batch of panels that fit the Hammond 12123 enclosure, and they also have touchpads, only a double-helix spiral pattern. They look pretty cool...pix at the bottom of this thread!
Panels, parts, and documentation are all on the site...for documentation, go to the bottom of the page and look for the links. If you have built a Lyra-8 or Lyra-4, I'd love to host pictures of your builds!
I spec'd the expansions with SP8T switches that were available from Adafruit. They seem to be out, but the switches are easy to find on AliExpress and other places. They are known as SR-16 1P8T, and I have managed to secure a source. I'm selling them for a bit less than Adafruit.
There are 2 panels for the expansion, as well. They both should fit a 19" rack. The main panel mounts the tweaks to either side of the Lyra-8 mainboard. They are made of PCB material in black, with white silkscreen and gold ENIG.
Main panel: $95 (19" x 7U)
I/O panel: $25
Standard panel: $40 (same price for Hammond!)
Standard I/O: Coming soon!
Gate in expansion: Coming soon!
There is a gerber posted for an experimental front panel sized to fit the Hammond 1444-12123 enclosure...the panel is meant to replace the bottom panel that Hammond sells to eliminate DIY drilling
ALSO it has conductive touch pads built in to the panel instead of using DIN screws, and drill guides printed on the backside (as well as traces) to mount toggle switches for shorting.
Also posted (in the next day or two) is a DXF file for anyone who wants to drill a Hammond 1456WL1BKBK enclosure to fit the expanded wings into an appropriately sized enclosure. I'll post a PDF of the graphics as well. (still working on this, Feb 2)
Lyra-8+ DIY Expansion Build Doc here
Expansion Bill of Materials here (also in the Build Doc)
Simple Schematic of Expansion here
Gerbers are available on the store in their own section (they are set up as products, but they are $0.00) There are some Gerbers missing, but only until I get the latest version finished...I did make some changes to both the main panel and the wings, but I will keep all versions of the Gerbers posted.
I'd love your feedback! Thanks for your support...developing this expansion has been really fun
