Lyra-8 DIY expansion and panels
Flounderguts
Re: Lyra-8 DIY expansion and panels
Post by Flounderguts » Thu Jul 30, 2020 9:50 am
Bjarne wrote:
Thu Jul 30, 2020 1:57 am
Yes, your standard panel design looks absolutely fabulous!
I note that you’ve skipped the screw holes for the 4 stand offs that normally hold the main board. Are they not needed?
Good point. Yes, I skipped the holes for the standoffs. I found that the pots and switches hold everything together just fine. But if you DO feel like you need standoffs, I marked the places on the back of the panel, so you can epoxy a set in place.
Flounderguts
Flounderguts
Post by Flounderguts » Fri Jul 31, 2020 12:41 am
I'm making sure everything fits the panels properly before I send them out.
Here is the standard panel built up with knobs from Tayda:
If you haven't started the part of the build with the pots and switches, I recommend doing it when you have the panel. That way, you can ensure that the height of the pot shaft and bushing is perfect...because the Tayda knobs I chose are not very deep.
You can see here that most of my knobs are way too high...but the ones in the foreground are better...they have a nut and a washer on the bottom of the bushing. You could also overlay the panel to a fixed PCB, and shim it to the height you want...but that's a bit more work.
Also, getting it all right at the beginning will hold the pots and switches in place very nicely for your soldering :tu:
Flounderguts
pendergast
Post by pendergast » Fri Jul 31, 2020 5:36 am
That looks awesome! I am still waiting for my Lyra-8 kit from SOMA. But I long to start this!
Flounderguts
Post by Flounderguts » Fri Jul 31, 2020 11:36 am
Welcome to MuffWiggler!
This is a great place to start :guinness:
Flounderguts
steviet
Post by steviet » Fri Jul 31, 2020 11:44 am
Soundcloud
D.Tilbury
Post by D.Tilbury » Sun Aug 02, 2020 1:48 am
Dude...they look incredible. I'm thankful to be involved with this thread. People are missing out by not seeing this thing. Whats the dragon ball z thing when fajita and those cats morph into the higher level characters? Thats this.
Then that last post.
Hahhahahhahahhah. Forreal!
-blippen
"Dirtle Tilbury"
D.Tilbury
Post by D.Tilbury » Sun Aug 02, 2020 1:51 am
Super sayin that dudes name is fajita.
-blippen
"Dirtle Tilbury"
Bamboombaps
Post by Bamboombaps » Wed Aug 05, 2020 12:33 pm
Trying to find a pcb before opting in for this
LegWyne
Post by LegWyne » Thu Aug 06, 2020 8:53 pm
I could be interested, what are you charging for the standard panel? has it been designed for 12x12 hammond enclosure or are they the original 10x10? (need to factor in the cost of a custom built 10x10 box if so)
Flounderguts
Post by Flounderguts » Thu Aug 06, 2020 11:20 pm
Standard panel: $40
It is NOT designed for a hammond case, or any other. It measures 266 x 266 mm, and I am in the process of getting a Fusion 360 file together with dimensions for a case.
I'm hoping to have an IO panel to go with the standard panel really soon.
Flounderguts
LegWyne
Post by LegWyne » Thu Aug 06, 2020 11:58 pm
Sorry to hear about your troubles that is a rough situation. Disaster recovery is no joke at the best of times. Well thanks for clarifying those points! I'll have a think and get back to you.
Flounderguts
Post by Flounderguts » Mon Aug 10, 2020 11:11 am
Expansion panels are here. They look fabulous!
Rather than try to gather money from everyone, I've set up a webstore to do that for me. I will have everything set up later today, and I will PM you each a link to the store, so you can pay that way (lots of options...paypal, venmo, cc, debit...)
Then, 10 days after I send the links, I will open the store publicly. Any unclaimed panels and stuff from the list of people will go to 1st come 1st served.
The gerbers and dxf files will be posted there as well, and as soon as I finish my build, a photo-heavy build guide. Also BOMs and links to parts.
Flounderguts
Addam
Post by Addam » Mon Aug 10, 2020 11:49 am
@Flounderguts
Looking awesome! :hyper:
Early on I bugged you about the project and you mentioned you were working on a circuit that would work with the i/o panel and allow for inputting of gates for individual voices. Please tell me this is still a possibility :hail: :hail: :hail:
Flounderguts
Post by Flounderguts » Mon Aug 10, 2020 1:31 pm
Yep, I have it breadboarded, but I don't have a working Lyra to test it. That shouldn't be a problem in the very near future. Hoping for gate in by early fall.
Flounderguts
Addam
Post by Addam » Mon Aug 10, 2020 2:00 pm
Yeeesssssss. Very cool.
I'm imagining with the right attack/decay envelope settings you could make a crude per voice volume control with a square wave lfo at the right rate (ie. envelope never reaches it's full peak or reduces to 0 while gates are plugging away). Sequencing this sounds fun. I'm gonna need some more OR combiners ;)
whyfarer
Post by whyfarer » Mon Aug 10, 2020 2:06 pm
:party: wowowow! they look amazing :hail:
Flounderguts
Post by Flounderguts » Tue Aug 11, 2020 9:32 am
Making progress on initial build and documentation...
Flounderguts
Addam
Post by Addam » Tue Aug 11, 2020 9:51 am
Hope you’ve been saving your resistor legs!
Flounderguts
Post by Flounderguts » Tue Aug 11, 2020 2:33 pm
Haha! I actually bought a roll of bus wire! Upper left of pic...that's not solder :yay:
Flounderguts
