Erica Synths DIY opensource
Girts23
Post by Girts23 » Fri Jul 10, 2020 6:24 am
Dear colleagues,
as Erica Synths discontinues its legacy DIY eurorack projects, we decided to make them opensource. We created Gerber files for PCB-made front panels and did slight changes in module design in order to get rid of custom and rare components, however some modules still require rare ICs and Delay module - a pre-programmed MCU board, which are available on www.ericasynths.lv.
Projects are available on https://github.com/erica-synths/diy-eurorack, and each project folder contains complete information and files to build a module: schematics, Gerber files for a front panel, Gerber files for PCBs, BOMs, component placement with values and designators and assembly manuals (please, note that some manuals are designed for older module versions).
By making these projects open source, Erica Synths accepts third party use for personal, educational or commercial purposes.
Erica Synths will not provide any support for these projects, please, refer to build threads here on Muffwiggler for information on build nuances, troubleshooting, part availability or alternatives.
Open source projects are:
Bassline – all in one synth voice for acid basslines and drones
BBD delay/flanger – all analogue effects unit based on V3205 BBD IC Delay – tape and digital delay unit with tap tempo, tempo sync, reverse, hold and add functions
Dual VCA – Polivoks architecture inspired dual VCA, rare Russian differential opamps are now replaced with AS3330
Envelope – recreation of Polivoks envelope generator with loop and end of attack functions
MIDI-CV – Polivoks functionality inspired dual MIDI-CV converter with glide function
Mixer – simple 3 chanel audio mixer
Modulator – Polivoks functionality inspired LFO, noise and S&H module
Output – Output module with headphone amplifier
Polivoks VCF – authentic recreation of the Polivoks VCF
Swamp – our take of Wogglebug module with lots of unique extras
VCO3 – Polivoks inspired VCO with nice extra – VCO Sync input
Thank you all for you support previously!
We, in collaboration with Riga Technical University, are now working on educational DIY kits for simple and affordable eurorack modules. We plan to announce them this Autumn.
Girts and Erica Synths team.
ixtern
Re: Erica Synths DIY opensource
Post by ixtern » Fri Jul 10, 2020 6:33 am
Great idea, thanks.
It would be nice to have a source code for the MIDI2CV module also (only hex is available) to customize it and maybe to fix some errors (module sometimes is going "wild" and refuses to work properly).
adam
Post by adam » Fri Jul 10, 2020 8:18 am
Great idea, thanks :)
Girts23
Post by Girts23 » Fri Jul 10, 2020 9:32 am
Great idea, thanks.
Yes, the code is in the MIDI-CV folder.
Enjoy!
Overand
Post by Overand » Fri Jul 10, 2020 9:53 am
This is such a great thing to do - thank you a ton!
Enjoy!
I only saw the .hex, not the source itself - maybe it’s missing?
Attributes:They/them, Queer, Enby, Poly*, Anti-hierarchy, Nature/Tech Weirdo
Sites: overand.com | SoundCloud | YouTube ModularGrid: Euro | MOTM
WTB: SynthTech E352/E370, Euro VCAs, Mixers, Env Followers
Building the modular since ~2003
ixtern
Post by ixtern » Fri Jul 10, 2020 10:45 am
Great idea, thanks.
Enjoy!
And where exactly is the source code? I can't find it...
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jul 10, 2020 11:08 am
I added micro swamp to my list of future projects.
KSS
Post by KSS » Fri Jul 10, 2020 2:19 pm
@Girts23
:tu:
mongrol
Post by mongrol » Sat Jul 11, 2020 2:19 am
Awesomely generous and most y33tworthy. Thank you Erica Synths.
autodafe
Post by autodafe » Sat Jul 11, 2020 9:01 am
coooooooollll !! thx a lot
socom93
Post by socom93 » Sat Jul 11, 2020 9:25 am
Thanks a lot Erica synth ! Really nice of you !
Stoneyards
Post by Stoneyards » Sat Jul 11, 2020 10:36 am
Props to you for supporting experimentation and education in the community!
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Jul 12, 2020 8:48 pm
is there a limit to how many swamp panels I can buy?
SphericalSound
Post by SphericalSound » Mon Jul 13, 2020 3:02 am
Bravo for Erika
:yay:
Dolphinwolf
Post by Dolphinwolf » Mon Jul 13, 2020 11:19 am
This is great news. How likely is it that someone will order a run of Swamp pcb’s? I would like one.
vaxdatex
Post by vaxdatex » Tue Jul 14, 2020 2:15 pm
This is great news and a great move by the folks at Erica Synths.
Thank you Erica Synths!
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Jul 14, 2020 8:41 pm
I am thinking about it. I need to look it over some more to see if there are any rare parts or calibration procedures to slow me down. if there is no support then I want to be sure I can follow it through before I jump in.
vaxdatex
Post by vaxdatex » Wed Jul 15, 2020 8:48 am
I went ahead and added all the content from the zip files into proper github repos for easier ingest into the process and tracking.
https://github.com/vaxdatex
Vax
Dolphinwolf
Post by Dolphinwolf » Wed Jul 15, 2020 12:01 pm
Looks like the sample and hold chip is hard to find but I wonder weather the TI LF398 is a substitute.
Troubleshooter
Post by Troubleshooter » Wed Jul 15, 2020 1:37 pm
Thank you very much EricaSynth!
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jul 17, 2020 5:07 pm
yes but this would require a redesign of the PCB. this was hard to find so I will post it here for your use.
datasheet2.pdf
KittenVillage
Post by KittenVillage » Fri Jul 17, 2020 5:22 pm
Any word if the MCU for the delay will have a released BOM and the firmware released?
Eurorack is an exercise in delayed desire.
Bamboombaps
Post by Bamboombaps » Sat Jul 18, 2020 3:26 pm
Bamboombaps
Post by Bamboombaps » Sat Jul 18, 2020 3:31 pm
Vax
Is there something wrong with the baseline files? I couldn’t preview the gerber
vaxdatex
Post by vaxdatex » Sat Jul 25, 2020 10:56 am
Vax
Just looked at a few and github shows the files.
