ARP 1047 SVF
dksynth
ARP 1047 SVF
Post by dksynth » Tue Jul 21, 2020 7:59 pm
I made my own version of the 1047 last year that I quite enjoyed.
But I don't completely understand some aspects of the circuit and I would like to. And maybe we can get some insight into how it works from some of the cleverer members here.... and maybe we'll be able to make something.
here is my redraw of the schematic:
I used my own little 4005 VCA chiclets:
Which used different combinations of matched or single transistors depending on what type of 4005 it was.
source: https://www.guitarfool.com/ARP2500/4005.html
The 1047 is an SVF with discrete transistor VCAs. VCA 1P and 3P are driven by the expo onboard VCA 3P. VCA 2N has its own expo onboard. 1P and 3P are the filter VCAs, 2N is the resonance VCA.
What'd I'd like to know is the "tricks":
Whats the deal with the diodes to and from +15 and -15?
The use of double matched FETS for the integrators with the opamps... I take it that fet input opamps weren't a thing yet? Is this better than modern fet input opamps?
Is there a precedent for the kind of lead/lag compensation in the LP feedback path? I don't see it used in later filters with similar performance. serge VCFQ used interstage compensation and the UAF used feedback path compensation without a trimmer. (unless you count the snip of wires to be a trimmer).
here was my VCA cards assembled:
My initial design used three of them in a serge voltage-controlled-triple-filter arrangement with automatic gain compensation between filters.
loki
Re: ARP 1047 SVF
Post by loki » Wed Jul 22, 2020 11:30 am
Using an OPA2134 or OPA1678 is superior to the dual FET and LM301. You are correct that there were no FET input op-amps when the 1047 was designed. The configuration Dave Rossum used a few years later in the UAF is an improvement over the 1047. He used the FET in a source follower configuration and followed it with an LM318.
teleport
Re: ARP 1047 SVF
Post by teleport » Thu Jul 23, 2020 11:40 pm
This thread may be of interest :
viewtopic.php?t=188193
The correspondence between Colin and Ashley in the pdf in loki's post there discusses the lead/lag circuit.
Am also curious about those stacked diodes on the ACOM and XCOM nodes. If I had to hazard a guess it'd be that they're forming a reference that is a couple diode drops away from ground - in practice the actual voltage drop through a diode depends on the current to a certain degree, so activity in the 4005's may appear there. When it's driven is there signal on those nets?
loki
Re: ARP 1047 SVF
Post by loki » Fri Jul 24, 2020 5:46 pm
For those interested, Dennis Colin's patent is: 3805091
guest
Re: ARP 1047 SVF
Post by guest » Fri Jul 24, 2020 8:22 pm
the diodes are acting as voltage references. the VCAs will perform better if the collector voltages on the diffpair transistors are similar. the 2 diodes make up for the 2 Vbe drops in the current mirror in the VCA. this reference is also used for the exponential converter to put the collector of the exponentiating transistor above (or below depending upon NPN/PNP) the diffpair emitters. this has the downside of adding temperature dependency on the CV to the exponential converter.
openmusiclabs.com
cygmu
Re: ARP 1047 SVF
Post by cygmu » Sat Jul 25, 2020 7:50 am
To the extent that I understand the phase compensation stuff, I learned the theory from Lee Thomas's paper
The Biquad: Part I-Some practical design considerations
IEEE Transactions on Circuit Theory ( Volume: 18 , Issue: 3 , May 1971 )
DOI: 10.1109/TCT.1971.1083277
The paper is about the biquad rather than SVF but there is a lot in common. The big difference is that there is only one feedback loop in the biquad circuit. In the paper Thomas calculates the effect of finite op-amp gain on the phase around the loop and its impact on the location of the pole and the Q of the filter and works out how to compensate it with a phase-lead capacitor. It is stated that the cap can be placed in parallel with any of the resistors around the loop, which makes sense.
It always struck me that in an SVF, because there are two loops, to get the compensation exactly right would require phase-lead caps in several places. I have not calculated to verify this thought but I don't see how it can not be true, and presumably Colin, and people like Serge etc. who also designed SVFs, were aware of it too. The Serge filters have caps in a couple of places presumably to keep the phase correct at all points in the circuit. However, tuning them all individually to set everything just right must be essentially impossible, especially for a production line rather than a one-off DIY effort. So my guess is that Colin decided to put just one cap in and tune it by hand to get things working as well as possible. Once that decision is made it probably doesn't matter where around the loop you decide to add the compensation.
The Real MC
Re: ARP 1047 SVF
Post by The Real MC » Sat Jul 25, 2020 6:30 pm
One of the first publications of a SVF design is IEEE 1968 Vol 56 pp 1137-1139 by J. Tow of Bell Labs. While not a complete analysis, it does have brief discussion of the sensitivity of the system.
I collected quite a few discussions on SVF analysis, including ElectroNotes. I have yet to see any discussion on phase compensation in dual loop SVF designs.
I haz a wrench, to fix da synth.
http://www.analoguediehard.com/
loki
Re: ARP 1047 SVF
Post by loki » Sat Jul 25, 2020 8:42 pm
Here is a copy of Active Compensation of Op-Amps. It is no specifically aimed at the SVF but it should be easy enough to apply. Especially because there are now inexpensive dual op-amps that are well matched.
The Real MC
Re: ARP 1047 SVF
Post by The Real MC » Sun Jul 26, 2020 1:48 pm
Had not seen that paper, thanks.
Bernie Hutchins
Re: ARP 1047 SVF
Post by Bernie Hutchins » Mon Jul 27, 2020 5:52 pm
I tried (in 2013) actively compensating the three SV blocks (summer, two integrators, all three separately) and reported the very mixed results:
http://electronotes.netfirms.com/EN215.pdf
No Magic Bullet! Since passive comp works quite well, and since it is unclear if the active comp can even be tweaked (with duals? perhaps), why not leave well-enough alone?
-Bernie
J3RK
Re: ARP 1047 SVF
Post by J3RK » Mon Jul 27, 2020 9:12 pm
-Bernie
I’ve been off the site for a bit, and never saw posts from you before... this might not be the exact right place for this, but can I just say you’ve been a big inspiration for a lot of the work I do! Thank you!
Continue the 1047 discussion here:
:mrgreen:
