Quad VCA, AC or DC coupled with normalized input
Haralds:Werk
Post by Haralds:Werk » Mon Aug 03, 2020 8:28 am
This is one more module for my quad system. It contains four VCA with normalized input, so you can distribute one input signal to four output channels. With each channel under voltage control you can move the input signal through the room dependent on the control voltages. I have two versions build one AC and the other DC coupled. Beside using this VCA's for signal distribution you can use every VCA independently. The gain to voltage ratio is linear. This is done because it is easier to predict the performance. The distribution of the signal must be steered through the control voltages. The implementation follows the recommendations from an article at Open Music Labs from October 3, 2015 (Minimizing distortion in OTA's)
Specs and features
• Four VCA with normalized input
• Usable as four independent VCA as well
• Linear gain to voltage response
• Individual Volume, CV and Bias controls
• Low distortion implementation
• Runs on +/-12V and +/-15V (with minor resistor value changes for best performance)
• Power consumption around 35mA each rail
The documentation and the Gerber files for download can be found in my website
www.haraldswerk.de
Home of Next Generation Formant
Studioalethea
Re: Quad VCA, AC or DC coupled with normalized input
Post by Studioalethea » Mon Aug 03, 2020 7:50 pm
What does the bias knob do?
I have been recently looking for a quad VCA whose behavior when normalled is actually 90 degrees phase-shifted down the line. So CV 1 (original), CV2 normalled is 90 degrees from CV 1, CV3 is 180 from CV1, etc.
Haralds:Werk
Post by Haralds:Werk » Wed Aug 05, 2020 8:53 am
With the bias you can open the VCA by hand. And it comes in handy when you are doing AM with a CV source which has only AC output. Say an LFO with -5V to +5V. Then you can attenuate the CV 1/2 with the CV pot and open the VCA 1/2 with the bias pot. This gives you the full LFO range without any gaps on the negative site of the LFO:
Good luck. This is usually done with a quadrature LFO running the phase shifted outputs in the four CV inputs from 4 VCA. That 's what I build my quad VCA for. A suitable LFO is here.
www.haraldswerk.de
Quinie
Post by Quinie » Sun Nov 29, 2020 6:04 am
And gerbers for panels. I have not tested these yet but the lfo fits nicely quite sure these will do also.
Quinie
Post by Quinie » Wed Jan 13, 2021 11:08 am
Thx again Harald.
Haralds:Werk
Post by Haralds:Werk » Wed Jan 13, 2021 11:51 am
Very nice!
www.haraldswerk.de
