Hello,
-- You mean, you used an actual "cooking" oven?
Yes a normal small pizza oven - OK baking pizza after using it as reflow oven isn't that good - but it's a cheap solution.
-- It seems to work pretty well! Resistors, capacitors, and SOT-23s look good. However, at least one of the QFN32 has some solder bridge.
Yes was a little bit to much solder paste I think, but you can remove the bridges quite easy.
-- By the way, what is your plan for your module?
-- Is it for sale as complete module or DIY? I would be interested by one.
Don't know at the moment - 1st take look at the schematic. As I already wrote - I didn't route all SSI pins to the socket.
If you can live with that I have some spare pcbs - at the moment I don't have any SSI2130 left, so I couldn't populate them anyway.
Bye
Ray
