Updated SSI2130 VCO Datasheet available...
neil.johnson
Re: Updated SSI2130 VCO Datasheet available...
Post by neil.johnson » Tue Mar 30, 2021 8:10 am
kybernetik wrote:
Tue Mar 30, 2021 7:51 am
neil.johnson wrote:
Mon Sep 28, 2020 7:03 am
The EXPO FREQ pin is a ground-referenced current input, limited to the range 0 to 200 uA. No negative current. As to what that means depends on the voltage-to-current resistors and the current going into the SCALE pin. The example given in the datasheet is for 20uA/octave (49.9k resistors), which is about the maximum you would want to go. Better would be 10uA/octave (100k resistors) and adjust SCALE accordingly.
Neil
Could you please explain what the danger is of a negative current going into pin 7?
I think in eurorack it's very possible to see a -10v input going into the 1v/oct input, so that's -10v over 100k = -100uA
Would that be a problem? Is there any maximum allowable negative current?
thanks!
If it goes negative then the VCO will stop, or run very slowly.
You, as the designer, are responsible for sanitizing (range limiting, scaling, offsetting, etc) the input signals to suit the parts you are using.
Neil
Random ramblings :: http://www.njohnson.co.uk
SSI parts and more :: https://www.cesyg.co.uk
kybernetik
Post by kybernetik » Tue Mar 30, 2021 8:51 am
Neil
Ok thanks, yes all inputs are sanitized, I just wanted to make sure there's no chance of :deadbanana: with a small negative current
Like what happened with the grounded mix inputs
- Cosmotronic -
neil.johnson
Post by neil.johnson » Tue Mar 30, 2021 9:13 am
Well, try to avoid any negative current since to do otherwise would mean you are operating the part outside of it's specified operating parameters.
Neil
JanneI
Post by JanneI » Tue Mar 30, 2021 9:25 am
neil.johnson wrote:
Tue Mar 30, 2021 8:06 am
Your DIP adaptor looks very similar to the one from SSI, but with the timing capacitor included:
http://www.soundsemiconductor.com/downloads/dab2130.pdf
Neil
Yes, I actually added the BW COMP 267R&10nF too. And hopefully, the bigger PCB works as intended, so that I don't need to use those adapters at all :-) The mission with this is trying to find out the "most musical implementation" by combining 2-3 of these VCOs, before advancing to the next objective. There's sure plenty of options to choose from. I'll report back!
neil.johnson
Post by neil.johnson » Tue Mar 30, 2021 9:41 am
You might want to try other values of TCAP. 3n9 is ok for audio, you could try a much larger value for LFO duties, or tweak the smaller value for different control range.
As you say, plenty of options!!
Neil
lickspittle
Post by lickspittle » Tue Mar 30, 2021 10:34 am
Neil
Just for laffs I lashed together a 2130 Maximus* mock-up...
*with all due respect to Thomas Henry
neil.johnson
Post by neil.johnson » Tue Mar 30, 2021 2:30 pm
Nice :tu:
burdickjp
Post by burdickjp » Thu Apr 01, 2021 12:16 pm
I'd love to see a few of these put together in a way like FSS OSC2 Recombination Engine or
Rossum Electro-Music Trident:
https://www.modulargrid.net/e/future-so ... ion-engine
https://www.modulargrid.net/e/rossum-el ... c-trident-
I've done PCBs from scratch before in KiCAD. I haven't done anything synth related. Where should I look to start?
I'm guessing power supply is something I can lift straight off of other open source modules. Any one in particular?
What else can I pull from open source?
KSS
Post by KSS » Thu Apr 01, 2021 4:08 pm
:popcorn:
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 02, 2021 3:06 am
Got my 2FW design working yesterday - still a couple of bits to tweak out for sure as I haven't gone deep yet...
- Sine section - following the DC coupled datasheet example, I need to figure how to trim it a bit though want to try to avoid having to add trimmers. I had a little play around the suggested 4k02 & 12k7 resistors but didn't quite catch a solution yet.
- 3-way waveform control (again from datasheet) - nearly there on this exciting part - proto has so far needed a little tweak or offset to go fully to triangle (which leads to some overtones or noticeable glitch in LFO mode) - again, trying to ensure that any design can be done without using trimmers or excessive numbers of different resistor values.
forestcaver
Post by forestcaver » Fri Apr 02, 2021 4:54 am
I ended up with an excessive number of resistor values!
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 02, 2021 5:21 am
Ah! To get a decent sine or for the waveform mixing?
On the sine-shape side - did you try with several builds as I imagine there might be some slight chip-to-chip variance. On old sine-shapers I always implemented shape & offset controls - could do here, of course, but would love a set & forget approach.
The waveform mixing is so close already... (though I scaled it up to 5V rather than the suggested 1v - played about a bit in Multisim & noticed that the control outputs go funny outside the particular input range - ie. for my 5V approach the input needs to be limited 0 to +5V)
forestcaver
Post by forestcaver » Fri Apr 02, 2021 8:19 am
Both! The sine is definitely acceptable for me... it’s not got a perfect fundamental with zero harmonics (but the harmonics are pretty low power and acceptable to me - cant remember the attenuation off the top of my head). I’m happy with waveform mixing - I used +/- 1.2v and scaled with opamps... I was very careful with the input currents....
I’ve built five and carefully tested three with spectrum analysis etc
If you want, I’ll email you my files - I’ll be sticking them on github some time soon anyway...
I’ll be over your way as soon as shops/lockdown eases in a couple of weeks to go to one of the bike shops round the corner from you so could drop in if you like? (Maybe a long extension lead to the garden as well!) I need to try your cider!
neil.johnson
Post by neil.johnson » Fri Apr 02, 2021 3:38 pm
One of the nice features of the sine converter in the SSI2130 is that if you overdrive it the result is quite pleasant. A lot of sine converters sound really bad if overdriven so you need to trim them quite carefully.
Neil
BugBrand
Knowledge of Bugs
Post by BugBrand » Sat Apr 03, 2021 5:54 am
Cool - cheers - I'm sure that it'll mostly come down to having some clear time to tweak values & investigate more.
Do pop by for a cider! - I'll make sure to save one of the last nice ones from a few years back (Frederick + various other bits) - workshop that is, near Stokes Croft.
forestcaver
Post by forestcaver » Sat Apr 03, 2021 2:20 pm
Excellent - thanks - just waiting for the Specialized shop to reopen :-)
I’ve sent an email with a load of stuff in it....
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 09, 2021 7:02 am
Hoping to get some tweaks in today...
Here's a quickie of the 3-way waveform morphing (voltage controllable) + you can see the offsided nature of the sine at present..
neil.johnson
Post by neil.johnson » Fri Apr 09, 2021 7:17 am
Wavemorphing looks good :tu:
Yeah that sine has a DC offset on it. Can you share your circuit?
Neil
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 09, 2021 7:21 am
Cheers!
Tweaked out the minor issue around that which was leaving a little smidge of ramp when it should have been tri only (which was overly noticeable in LFO mode)
The sine is DC coupled exactly as in the datasheet suggestion (4k02 input resistor from tri & 12k7 offset from vref) - will be tweaking these shortly even though it is tight in there on my board!
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 09, 2021 8:48 am
Increasingly thinking there's something screwy on this first build around that area...I tried adjusting values to no avail & just verified DC coupled sine on my older proto board so will proceed to build a 2nd of the new version to cross-compare.
neil.johnson
Post by neil.johnson » Fri Apr 09, 2021 8:49 am
Worth checking the components are the correct ones? The required value of bias resistor according to the math is 12k79, but that's a non-standard value and 12k7 is close enough.
Neil
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 09, 2021 10:54 am
Yes, I did check I hadn't done a booboo on values or such but.. seems my issue must have been something on soldering the 2130 - part-way through building another & have just confirmed good sine with the suggested DC-coupled values.
tIB
Stainer!
Post by tIB » Fri Apr 09, 2021 11:35 am
Like the look of that three way morph!
J3RK
Post by J3RK » Fri Apr 09, 2021 1:49 pm
That’s why resistors come in 1% :lol: I think ALL of my circuits have way too many values. I just use what makes things look and sound good. Hardly scientific. :hihi:
Tonescape
Post by Tonescape » Sat Apr 10, 2021 2:29 am
Oh yeah, looks great! Is this done with the example from the data sheet? Thanks 🙂
_________________________________________________
www.bragi-modular.com - www.instagram.com/momecmusic
