Debugging Shruthi XT- digital noise on output
djs
Post by djs » Fri Sep 11, 2020 7:58 am
My Shruthi XT is getting a lot of digital noise on the output. I don't think it's the display as it's very loud- much louder than the normal sound itself (which also sounds distorted). It seems to come on after 2-3 seconds of being on, and is fairly continuous ie. not affected by the envelope. Changing screens or settings seems to trigger it, but it's really hard to say. Also, the filters don't filter the noise in any way, so maybe it's on the ground line? IDK.
To be honest, I'm not a digital guy- any suggestions on where to start? FYI- I'm using the CS80 filter board on it.
Your help is appreciated!
"Noise is what the Earth is made of" - David Bowie
cnicht
Re: Debugging Shruthi XT- digital noise on output
Post by cnicht » Fri Sep 11, 2020 2:22 pm
What sort of power supply are you using?
djs
Post by djs » Fri Sep 11, 2020 3:07 pm
wall wart- 9v 1amp supply.. so I don't think it's under powered?
Bjarne
Post by Bjarne » Fri Sep 11, 2020 4:01 pm
Just checking: have you selected ‘svf’ in the filter settings?
djs
Post by djs » Fri Sep 11, 2020 5:20 pm
Yes - filter setting is correct :).
snowtires
Post by snowtires » Fri Sep 11, 2020 7:08 pm
Man, I had lots of problems with Shruthis and 9v supplies, I always used a 12v
cnicht
Post by cnicht » Sat Sep 12, 2020 2:08 am
Have you looked at its output without it being connected to the Shruthi?
Altitude909
Post by Altitude909 » Sat Sep 12, 2020 8:15 am
what type of display are you using
djs
Post by djs » Sat Sep 12, 2020 9:39 am
Ok- so I switched out to a 1amp, 12V supply and it had the same problem. I notice that once the digital sounding garbage starts (about 5-10 seconds after turning on) the sound other than the digital noise sounds like it has a LPF on it, no matter what the actual setting is. It works before the 5-10 seconds, so I know I have the settings right. I have a theory that maybe something is funky with the CD4053s on the filter board? Thoughts?
Not sure what the display is... or at least I can’t remember what I put in there.
cnicht
Post by cnicht » Sat Sep 12, 2020 10:35 am
It sounds like something is heating up and generating random oscillations
Altitude909
Post by Altitude909 » Sat Sep 12, 2020 10:40 am
Was it an OLED or a LCD with LED backlight
djs
Post by djs » Sat Sep 12, 2020 5:48 pm
Looks like an LCD with backlight
AlanP
Post by AlanP » Sun Sep 13, 2020 2:15 am
Are you running wires for the volume pot, or using the built-in volume thing?
Altitude909
Post by Altitude909 » Sun Sep 13, 2020 6:30 am
Sounds like digital bus noise. Does it get worse when you turn one of the pots? Has anyone actually tested the CS80 filter on the XT?
Flounderguts
Post by Flounderguts » Sun Sep 13, 2020 7:51 am
Me. I have an XT with CS80 filter. No issues.
Flounderguts
djs
Post by djs » Sun Sep 13, 2020 8:15 am
Yes it does... or when menus are changing.
Also I’m using the built in volume knob... no wires
djs
Post by djs » Sun Sep 13, 2020 4:30 pm
I posted a sample of it on IG here:
It worked fine for about 2.5 min and then did this. Maybe it’s overheating? Something more digital based? A cap that’s charging up slowly and then getting angry?
Next step is to take it apart and see how hot everything gets when it starts glitching?
Flounderguts
Post by Flounderguts » Tue Sep 15, 2020 7:46 am
Are you using RAM different from what was specified? Someone posted about digital noise from RAM in MI DIY thread.
Flounderguts
djs
Post by djs » Tue Sep 15, 2020 9:08 am
Interesting- I don't think so, but I'll check!
snowtires
Post by snowtires » Tue Sep 15, 2020 9:18 am
Check the soldering around the Atmega and the CD4051, maybe replace the 4051 if you have an extra since they're cheap. They're the two chips that deal with the digital aspects of the Shruthi and how it reads the pots
Altitude909
Post by Altitude909 » Tue Sep 15, 2020 9:25 am
no ram in the shurthi, its ATmega644 based, not ARM like the one in the DIY thread
cnicht
Post by cnicht » Tue Sep 15, 2020 2:28 pm
Have you measured the power rails when the fault occurs?
snowtires
Post by snowtires » Tue Sep 15, 2020 3:15 pm
Speaking of making sure the filter is on the right setting, I vaguely remember there being either a specific power on combo or a menu setting to signify that it's a Shruthi XT. It's been a few years since I built one, I forget what the deal was, but seeing the display going crazy like that in the video reminded me of it.
snowtires
Post by snowtires » Tue Sep 15, 2020 3:19 pm
From Emilie: Try booting the synth with the encoder pressed until the screen shows:
shruthi xt
(full control)
From this thread:https://www.google.com/url?sa=t&source= ... Ehk0c9tf3k
The OP in that thread's issue was caused by two swapped chips, check that out on yours
