How to test if my 4006 is working
SPoT_D
Post by SPoT_D » Sun Sep 13, 2020 8:21 am
Hi there!
I have a beginners question. I'm trying to build a digital noise source with a 4006 and a 4070,
The 4070 is working as I can easily test a gate, but how do I test if my 4006 is working?
The circuits I build do nothing (but I don't know why):
https://gr33nonline.files.wordpress.com ... 510&crop=1
https://electro-music.com/forum/phpbb-f ... v3_603.png
I'm also open to other designs making a similar sound..
FetidEye
demonic space drone
Re: How to test if my 4006 is working
Post by FetidEye » Sun Sep 13, 2020 11:38 am
if you do something basic with leds connected to the outputs and send it a clock and a data (also a clock) for example a cd40106 oscillator.
you will see if something happens
tele_player
Post by tele_player » Sun Sep 13, 2020 11:41 am
The LED idea is good.
This would also be a good use for a super cheap DSO138 scope.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Sep 13, 2020 1:20 pm
You can load data or clocks manually with toggle switches and pullups. This will wait for input at the clock. You can probe it without the LED. Whatever way is easier for you.
devinw1
Post by devinw1 » Sun Sep 13, 2020 1:40 pm
Also, the output of that chunk of 4070s should be a square wave signal, probably like 80KHz or so. If you don't have that, then you won't have noise either.
