mutable instruments module tester enclosure / case
hello all
I'm building one of the module testers designed by mutable instruments. I wanted to make an enclosure for it similar to the one shown on their site. unfortunately they don't seem purchasable currently. émilie being incredible shared her design; unfortunately the dimensions are too large for at least ponoko's laser cutter
I slightly rearranged the pieces so they can fit and adjusted the file to meet ponoko's requirements. I thought I should share the file in case it's helpful to someone
the file is encapsulated postscript (.eps) but such files aren't allowed to be attached, hence .txt. change the name back to the .eps extension (module_tester_case_edited.eps) after downloading it
I have to give the caveat that I have yet to build this but will report back after doing so
I hope this is useful to some of you
- Attachments
- module_tester_case_edited.txt
- encapsulated postcript, rename to module_tester_case_edited.eps
- (127.51 KiB) Downloaded 13 times
Re: mutable instruments module tester enclosure / case
actually - are other people interested in a group buy? prices improve after buying 5
- synthetek
- Veteran Wiggler
- Contact:
There used to be a few module tester and shruthi cases already on ponoko to order. Seems like they are gone now even my own modified ones don't show up in my account anymore.
I can happily report that the enclosure .eps/.txt file posted earlier works with the most recent (v2) module tester board from amazing synth :) I used ponoko but I imagine others will be fine too
a few comments for anyone else who wants to build one of these:
hope this is useful to someone :)
- when ordering, be sure to mark the borders (red) as cutting, the labels as line engravings (hollow black), and the logos as area engravings (solid black)
- for v2 pcbs, the holes on the bottom seem to be without function and can likely be removed from the schematic
- using the amazing synth bom midi jack (Circular DIN Connectors DIN, 5P jack, rt, through hole), I had to trim the bottom to get it to fit
- assembly can be done with 9 standard eurorack (M3x0.5) screws
- 40mm fully threaded screws x4 for the top and bottom (enclosure height is 39mm; if you have access to an esoteric 42mm screw that's probably ideal)
- 12mm screws x4 for the sides
- standard rack mount screw (~8mm) x1 for the heat sink (not technically part of the enclosure but included as it's not in the amazing synth bom)
- nuts x17
- 8 to secure the board top and bottom
- 4 for the sides
- 4 for the bottom (I used acorn nuts)
- 1 for the heat sink (again not technically part of the enclosure)
- washers x4 for the side screws
- if you use thonkiconn jacks, you need to use washers (x6) as the knurled nuts are nearly the size of their enclosure openings
- Learning to Wiggle
This might be very useful to me. I built a module tester but was having trouble modifying the case design to work with a laser cutting service. Thank you!
- synthetek
- Veteran Wiggler
- Contact:
Here is file that I have used with ponoko a few times, It says 12 AC adapter on the back and the newer boards use a DC adapter so you could change or delete that depending on what version you have.
- Attachments
- module_tester_ponoko2.zip
- (263.89 KiB) Not downloaded yet
you can also put a standoff under the lcd/encoder (thats what the hole in the middle is for)dkmb wrote: ↑Wed Dec 30, 2020 10:49 pmI can happily report that the enclosure .eps/.txt file posted earlier works with the most recent (v2) module tester board from amazing synthI used ponoko but I imagine others will be fine too
apologies if this is all obvious; I don't know much about engineering and am learning about building these delightful instruments as I go
- nuts x17
- 4 for the sides
hope this is useful to someone![]()
- bgreeves
- Common Wiggler
- Contact:
Wait wow, I really should have checked the timestamp on the OP. That said, I'm down if anybody else wants to organize a group buy
oh, that makes sense. do you know what size works? I ended up soldering the LCD on with old lead trimmings since I couldn't figure out what the better way to do it would be (couldn't find an appropriately-sized pin/socket).
sorry! :)
it's the same as the long ones on the corners, can't remember the size
