UA741 and UA741TC interchangeable?
MoyaMoya
Post by MoyaMoya » Sat Oct 17, 2020 8:47 pm
I've been looking for a solid answer on this
and don't quite understand the datasheets as I dont see any specific info for the TC
but im 90% sure they are interchangeable
and I would like to be 100% sure
thank you for your time
snowtires
Re: UA741 and UA741TC interchangeable?
Post by snowtires » Sat Oct 17, 2020 9:27 pm
You'll be fine
MoyaMoya
Post by MoyaMoya » Sat Oct 17, 2020 10:05 pm
thanks!
Studioalethea
Post by Studioalethea » Sat Oct 17, 2020 10:36 pm
Suffixes are generally a combination of a tolerance identifier and a package identifier. T is the package here and C is a commercial spec. Not sure if this is the data sheet you found or not: https://www.datasheetq.com/datasheet-do ... ld/UA741TC
It shows all the different packages with their suffixes. “T” is just a 8-pin DIP (bottom left) and in the specs (middle of the page) you can see the difference between military spec (“A”) and commercial.
Also, pretty much anything with a 741 in it will do. LM741, etc.
Portabella
Post by Portabella » Sun Oct 18, 2020 3:15 am
btw I have a bunch of metal can UA741 I no longer need.
if anyone wants/needs them, hit me in the DMs
