Eagle Files - VCO, Filters, Touch, and SeqSw
AlanP
Re: Eagle Files - VCO, Filters, Touch, and SeqSw
Post by AlanP » Wed Nov 25, 2020 12:41 am
The Wave-Ctl and Sine-Trim trimpots are interactive, to a degree -- you'll need to adjust both at once to get the best sine wave. Make sure the panel pot is set to Sine before doing so (I don't wanna talk about it...) and flick it back to the other waveform after trimming the Sine to check how the other waveform for that oscillator works out. You're probably going to have to either settle for a compromise, or sift through a load of different jfets to get a good sine that also gives a good square/ramp (it's not a particularly good sineshaper, but it does do morphing between them.)
For v/oct and freq, it's pretty much as normal.
skautkurt
Post by skautkurt » Wed Nov 25, 2020 6:20 am
I feel you there hehe
Thanks for the discription, the 258 and the 291 will be my holiday-leisure-projects.
bcitral
Post by bcitral » Sat Dec 05, 2020 8:47 am
Afternoon all, can I query res pot. Its 5kb right?
A mild euro crack habit.
skautkurt
Post by skautkurt » Thu Dec 17, 2020 6:11 pm
Should be, yeah.
I built one of the 291s tonight, but have not tried it out yet. Will do tomorrow night. Is there anything hacky or specific to look out for?
T
egilegilegil
Post by egilegilegil » Thu Dec 17, 2020 7:02 pm
I built a 291 today. Such an incredibly juicy filter! It's got that wonderfully gurgly smooth vactrol response, also love the narrow bandwidth for picking out overtones without selfoscillation. Thanks AlanP for doing this!
I have a question regarding the response of the frequency CV potentiometer. Mine is incredible sensitive in the middle of the travel, it's almost an all CV off or on type situation where all the action of the travel happens very close to 12o clock. I suspect this is due to the vactrol nature of the circuit? Is it worth experimenting with different vactrols for a more even response, or is there some other solutions? What's your experience, how does your modules behave? I used a linear 10kb potentiometer btw.
Furthermore I’m getting some self oscillating at low (40hz ish) frequencies when the bandwidth is at its most narrow (with the filter cut off in this low range). Is there any remedy for this?
Cheers!
skautkurt
Post by skautkurt » Fri Dec 18, 2020 11:59 am
Cheers!
Huh, just tested mine, I think my vactrols work so well... the freqency pot does nothing at all, similiar to the q. Only the Bandwith really changes anything, and I think it only overdrives the signal. Which vactrols did you use? Xvive? Aliexpress ones (mine are)? DIYed ones?
T
egilegilegil
Post by egilegilegil » Fri Dec 18, 2020 12:28 pm
Cheers!
T
I see, too bad :( , I used xvive vactrols from thonk. Hope it get's sorted!
skautkurt
Post by skautkurt » Fri Dec 18, 2020 1:09 pm
Ups, I meant: I think my vactrols DONT work so well*
skautkurt
Post by skautkurt » Fri Dec 18, 2020 5:40 pm
Some more testing happend, and I am quite sure, that my vactrols are at fault. I have some very limited response on the frequency and the bandwidth pots, meaning they only show effect in the first few degrees of turning. I now ordered some LDRs and LEDs and will try to experiment with those. And if that does not work... well. I might need to bite the (really quite sour, as they are super expensive here in germany) apple of buying some VTL5c3s.
egilegilegil
Post by egilegilegil » Sat Dec 19, 2020 12:32 pm
This thing can deliver some serious acid bass lines :sb:
Bamboombaps
Post by Bamboombaps » Sat Dec 19, 2020 2:15 pm
Sounds awesome 👏
bcitral
Post by bcitral » Thu Dec 24, 2020 5:46 pm
thanks for the info. Mine is built now but not passing audio. I think I bought a batch of fake TL072's.
1WILDTHING
Post by 1WILDTHING » Sun Dec 27, 2020 3:56 am
Hi guys, I'm about to start this Buchla VCO project using the 0.1 brd layout. Suddenly I've realized that I miss the Tempco resistor required in R55. Could you please tell me which one you have chosen or you can recommend for this build?
AlanP
Post by AlanP » Sun Dec 27, 2020 4:02 am
The ALT resistor locations can be used instead. If you later get a tempco resistor, you can remove the ALT resistor and place the tempco.
SphericalSound
Post by SphericalSound » Sun Dec 27, 2020 9:13 pm
If anybody has 291 spare PCBs I would gladly pay for the shipping plus a pair of beers.
I would go for homebrew vactrols. Any tutorial on how to match them?
1WILDTHING
Post by 1WILDTHING » Mon Dec 28, 2020 4:36 am
Thanks Alan, but I have to admit that I don’t know what a ALT resistor is. Could you be so kind to explain what kind of resistor is? 😅
skautkurt
Post by skautkurt » Mon Dec 28, 2020 11:11 am
Not Alan, but I think the ALT just means ALTernative. So, if you chose against using the Tempcos, you have to put an equivalent "normal" resistor there, meaning just a normal 2kohm resistor.
skautkurt
Post by skautkurt » Mon Dec 28, 2020 11:14 am
I will try some tonight, or tomorrow, and will experiment with GL5539 and GL5549 LDRs plus some different LED colors and strengths. I will report my success or failure here ;)
AlanP
Post by AlanP » Mon Dec 28, 2020 11:01 pm
Bingo.
1WILDTHING
Post by 1WILDTHING » Wed Dec 30, 2020 1:38 pm
Bingo.
Thanks guys!
romain
Post by romain » Wed Dec 30, 2020 2:38 pm
:hail: Thanks a lot
skautkurt
Post by skautkurt » Sat Jan 02, 2021 5:39 pm
Tried the 291 with GL5549 and green LEDs. Works, but only reaally sluggish. Not really fun. Looked into the datasheets again and saw my mistake. GL5549 have a rise up time of 20ms, the VTL5c3 only need 2.5ms for that :doh: :doh: Stupid me. Well. I think I'll lay it to the side for now.
Cheers.
edit: driving the leds more by chaning R20 and R25 to 750R made it a bit more fun. Will experiment further and share my results.
skautkurt
Post by skautkurt » Sun Jan 03, 2021 5:17 pm
Okay. Now I tested the GL5549 with ultrabright, clear, flattopped LEDs. And its way better. If I calculated correctly my LEDs with the 1k resistor are driven at around 8mah, in Scott Stites schematic the LEDs of the Vactrols get up to 11.8 (again, if my calcs are correct). I will try to reduce the resistors R20 and R25 to get a similar result.
1WILDTHING
Post by 1WILDTHING » Sun Jan 10, 2021 2:43 am
Hi all. I’m trying to populate the 258’s 0.1 board. I’ve found almost all resistor values but I can’t find value for resistors called IP1 and IP2 (close to power socket). May be have they to be omitted and wired over (like r25, r34, r72 and r79)?
skautkurt
Post by skautkurt » Sun Jan 10, 2021 1:05 pm
IP1 and IP2 are input/power protection, I think, and should be either a 10 Ohm resistors or ferrite beads (I think!!) Maybe AlanP can comment on this?
Edit: as AlanP stated on the first page of the thread, the omit resistors should be left free, and not be wired over. So no connection instead of 0 ohms.
