Anyone recommend a US source of reasonably priced tants?
lusoman
Post by lusoman » Sun Oct 18, 2020 7:56 pm
Looking for 35V and 50V tants. Mouser and DigiKey have them but they are priced at $4-5 each for 10u and above. AllElectronics don't seem to have anything above 25V.
Call me old-fashioned, but I like a dump to be as memorable as it devastating.
col
Re: Anyone recommend a US source of reasonably priced tants?
Post by col » Sun Oct 18, 2020 9:09 pm
Don't use them, they fail short-circuit!
B0bcat
Post by B0bcat » Sun Oct 18, 2020 9:29 pm
Several Haible Designs use them. What’s the supposed benefit over “regular” electro caps?
WTB:
Malekko/Wiard Oscillator / Anti / Borg (Gargoyles),
Plan B Model 12 / 13 / 15,
Macro Machines Storage Strip,
Intellijel FlipFlop
Flounderguts
Post by Flounderguts » Sun Oct 18, 2020 11:00 pm
I read that first as "reasonably priced taints," did a doubletake and got "reasonably priced pants."
Then I cleaned my glasses.
Flounderguts
Mungo
Post by Mungo » Mon Oct 19, 2020 12:03 am
Historically they were smaller in size for the same ratings. But there have been improvements in low ESR electrolytics, and closely related aluminium "polymer" caps are newer replacements for tantalum.
lusoman
Post by lusoman » Mon Oct 19, 2020 9:03 am
If I do go with electros, then, is there any advantage/disadvantage in using non-polarized ones? For a start, I kinda like the luminous green they often come in?
mskala
Post by mskala » Mon Oct 19, 2020 9:20 am
Non-polarized capacitors are usually bigger and more expensive, but you need them if you will be applying reverse voltage. There is no particular electrical advantage to polarized capacitors - a circuit meant to use them will work with non-polarized too - but the polarized capacitors are often cheaper and smaller.
MikeDB
Post by MikeDB » Mon Oct 19, 2020 9:22 am
Provided your circuit can take it the much lower ESRs, consider 50V MLCC capacitors as an often cheaper and non-polarised alternative to tants.
But don't put them on the output of a prehistoric voltage regulator like the 78xx series as they don't mix well.
Personally I hate cats ! Charlie the jackdaw on my shoulder also hates cats as his mother was killed by one so I had to raise him until he set off to procreate his lineage.
MikeDB
Post by MikeDB » Mon Oct 19, 2020 9:24 am
Most electrolytics dry out over time and need replacing after a few decades, but non-polarised do seem to need replacing a little earlier. Not sure why.
B0bcat
Post by B0bcat » Mon Oct 19, 2020 1:35 pm
such as these, 647-PLV1J220MCL1TD (Mouser)?
WTB:
Intellijel FlipFlop
Mungo
Post by Mungo » Mon Oct 19, 2020 4:15 pm
Yes, that would be an example part.
Dave Peck
Post by Dave Peck » Mon Oct 19, 2020 4:23 pm
I nearly always get the best results by using Octopart.com. If you just want to find stock at the best price it helps if you have already narrowed your search down to a few readily available mfgr's part numbers, but you can also do a wider search based on description.
