Buchla Random Voltage Source - Convert to Eurorack?
GKMendenhall
Post by GKMendenhall » Thu Nov 19, 2020 3:09 pm
Hello everyone!
I've got my eye on building this Buchla random voltage source schematic as a eurorack module. Can anyone give me some advice on what component value changes I would need to make in order to make it work the same with +12V instead of the +15V listed in the schematic? Still pretty new at this...
fluxmonkey
Re: Buchla Random Voltage Source - Convert to Eurorack?
Post by fluxmonkey » Fri Nov 20, 2020 8:58 pm
i have PCBs available for this: http://fluxmonkey.com/fluxmerch_buchla.htm. it runs fine on 12v without changes. the outputs swing close to the rail, though - i usually build mine with attenuators on the panel for each out, or voltage dividers behind the panel to bring them down to a more reasonable level.
www.fluxmonkey.com
BUILDER FOR HIRE - kits or custom, email me with your needs
GKMendenhall
Post by GKMendenhall » Sat Nov 21, 2020 8:42 am
Thanks!!
How do I add an attenuator for each output on the module?
I also have a PCB for an attenuator module, so that could work, too.
GKMendenhall
Post by GKMendenhall » Sat Nov 21, 2020 7:00 pm
I did some digging on this.
Should I just add a B100K pot right before the output jack and that's the attenuator?
fluxmonkey
Post by fluxmonkey » Sat Nov 21, 2020 8:25 pm
yeah, as a voltage divider:
www.fluxmonkey.com
3hands
Post by 3hands » Sat Nov 21, 2020 8:36 pm
Forgive my ignorance, but is this not a Wogglebug?
Gum is fun, but not on a cat.
My minds an art gallery.
GKMendenhall
Post by GKMendenhall » Sat Nov 21, 2020 9:24 pm
No. The Wogglebug uses a different design.
This is just one clock in and four random cv outs.
GKMendenhall
Post by GKMendenhall » Sat Nov 21, 2020 9:25 pm
Thanks for your help!
mritenburg
Post by mritenburg » Sat Nov 21, 2020 9:38 pm
The Wogglebug is based on the Buchla 265 source of uncertainty, just FYI.
fg
Post by fg » Sun Nov 22, 2020 2:14 pm
hello,
the "portamento" function is probably possible with this circuit ?
GKMendenhall
Post by GKMendenhall » Mon Nov 23, 2020 5:41 pm
hello,
Thanks for the Idea! I think I'll give it a try!
MOOGi
Post by MOOGi » Mon Nov 23, 2020 5:54 pm
If it works not properly with only +-12V use two Step_up converters which can change the +12V to your +15V
MOOGi
Post by MOOGi » Mon Nov 23, 2020 6:03 pm
and the second Step_up can change the -12V to your -15V
