2021 : which soldering station, desoldering gun, etc,?
BlinkyLights
Post by BlinkyLights » Wed Jan 06, 2021 6:41 am
I need a new, complete, setup for personal TH & SMT. Will be soldering bunch of 1/4" cables/snakes soon, the occasional DIY module, and repairing/modding various.
Hakko FX888s seem decent enough, especially for $100.
But the Hakko corresponding Desoldering gun is $250+.
Then I see things that seem too good to be true, like a Soldering and Desoldering pair from YIHUA for $150.
Suggestions, comments, etc?
Thanks, much.
Flareless
Re: 2021 : which soldering station, desoldering gun, etc,?
Post by Flareless » Wed Jan 06, 2021 6:54 am
Do yourself a favour and don't cheap out. There's nothing worse than having to buy the right gear after suffering through the wrong gear.
I've got a Weller WE-1010 soldering station and a Hakko FR301 desoldering tool. I find the pair unbeatable.
Good luck in your search.
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
aphantomvaper
Post by aphantomvaper » Wed Jan 06, 2021 7:36 am
What, no more hot nail and candle?
Don't cheap out as mentioned. The Chinese stuff is cheap but only "good" and will fry in a couple years. 4 years and two soldering rigs later and go m looking again also.
The only thing that stays the same is change
cackland
Post by cackland » Wed Jan 06, 2021 8:02 am
TS100 and hot air gun work a treat
sir stony
Post by sir stony » Wed Jan 06, 2021 8:18 am
I have very good soldering gear at my work (JBC), but at home and for my studio cables and all that, I have a Weller Magnastat T40e with 21021 station from 1976, exactly like this one. (ebay link)
I can still get the spare parts, as the guts of that Magnastat system hasn't changed in all those years. There was no need, it works extremely well. It has been something like the industrial standard and I'd guess it will still be around for another couple of decades.
skulptr
Post by skulptr » Wed Jan 06, 2021 9:01 am
ERSA also comes highly recommended, I have the RDS80 with a variety of solder tips:
https://www.kurtzersa.com/electronics-p ... ds-80.html
Or, if you're in Europe:
https://www.ersa-shop.com/ersa-rds80-el ... p-926.html
Mind you, that is only for soldering (and the basic desoldering using solder wick or manual vacuum pumps of course).
If I understand you correctly you are also looking at a decent desoldering setup? That tends to get expensive very quickly which is logical as it involves much more moving parts (filters, a compressor unit or electronic vacuum pump, a more complex desoldering tip, ...).
That Hakko gun you mention is still quite cheap then because the ESRA X-Tool Vario sets you back about 450€/$ and requires something much fancier than an RDS80. You are then looking at something like an i-CON Vario 2 with (amongst other things) a built-in vacuum pump:
https://www.kurtzersa.com/electronics-p ... o-2-1.html
But that setup sets you back about 1200 to 1500 €/$ depending on the exact soldering and desoldering guns you want. :mrgreen:
Flareless
Post by Flareless » Wed Jan 06, 2021 10:37 am
Just curious if you've picked anything out yet to hold your PCBs while you use all this fancy soldering gear?
Rich
msegarra
Post by msegarra » Wed Jan 06, 2021 11:03 am
I have the hakko desoldering gun and it works great
Stoneyards
Post by Stoneyards » Wed Jan 06, 2021 12:02 pm
Hakko fx888 is a high quality bargain. I’d not worry about a matching desoldering kit.
Do strongly consider fume extraction and a panavice or similar pcb holder.
My surprise fave was a hakko double solder roll holder - it doubles as a tool holder and magnetic base for helping hands etc.
pricklyrobot
Post by pricklyrobot » Wed Jan 06, 2021 12:11 pm
Panavise is an excellent choice, though I found this head: https://www.panavise.com/index.html?pag ... udatarq=22
to be way more useful for holding PCBs (and lots of other stuff) than the one that’s actually marketed as a ‘Circuit Board Holder’.
jimfowler
Post by jimfowler » Wed Jan 06, 2021 2:38 pm
DanaFo
Post by DanaFo » Wed Jan 06, 2021 3:11 pm
I am pretty new and I agree about spending decent money HOWEVER, I got a very good iron that made me feel like a soldering god compared to the 2 cheapo kits I tried before:
https://www.amazon.ca/gp/product/B07V8S ... UTF8&psc=1
I'd also advise the spend on solder too. I got burned from a massive splatter from cheap chinese solder (I think it's tabiger?) and thank god I was wearing eye protection.
Is there a cheap desoldering gun that's worth it yet? I got the engineer sucker and it seems very handy to have the silicon tip to seal the join.
soejrd
Post by soejrd » Wed Jan 06, 2021 4:07 pm
Got a TS100 for 50 bucks and it's amazing! The first two solder jobs had a learning curve, but it's so handy, maneuverable and easy.
noobyist
Post by noobyist » Wed Jan 06, 2021 4:12 pm
I first bought an ERSA ICON PICO, regulation and standby are excellent but I was very disapointed by the soldering tool: there is a designing issue and it's almost impossible to tighten the tips without damaging the tool thread.
The ERSA I-CON NANO seems to have a better tool, so that would be a better bet, with ESD as a bonus. (however, I did not try it myself)
Now I own a Weller WE-1010 that I find very reliable, however the regulation is not as fast as the ERSA and the standby is not very accurate (it tends to go to sleep while you are trying to make a joint...)
ketem13
Post by ketem13 » Wed Jan 06, 2021 4:36 pm
I bought a KSGER T12 from ALiExpress a year ago and I'm super happy with it.
You have control over the temperature and sleeping mode if your forget it on.
I did plenty of soldering in the past few months and had no issue at all.
I never tried Hakko or a Weller but I think the KSGER T12 is very good for the price.
cackland
Post by cackland » Wed Jan 06, 2021 5:09 pm
I think these PCB holders are great.
Check out PCBite.
https://sensepeek.com
mor4sso
Post by mor4sso » Wed Jan 06, 2021 5:18 pm
Weller WES51 is god.
paperCUT
Post by paperCUT » Wed Jan 06, 2021 5:41 pm
I've had a long life out of a cheap Aliexpress station with weller tips. Just saying....
twigathy
Post by twigathy » Wed Jan 06, 2021 6:31 pm
I got one of these back in March and it's held up well so far: amazon.co.uk/dp/B07X3CZ3FJ/
The dead simple set-and-forget temperature is really good, and it comes with a couple of different tips although I've only used the smallest chisel-type tip. The solder bundled with it was fine and worked decently enough, but once it ran out I got myself some "real" solder from Chip Quik which has been a little easier to work with in a way I'm not sure I can properly describe. https://cpc.farnell.com/chip-quik/smdsw ... dp/SD02715
BlinkyLights
Post by BlinkyLights » Wed Jan 06, 2021 6:39 pm
I had high hopes for a harem of helpers.
abelovesfun
Post by abelovesfun » Wed Jan 06, 2021 6:52 pm
Super Easy, Awesome DIY kits @ http://www.aisynthesis.com
modular ambient and composery music @ http://www.forcedamage.com/
https://www.facebook.com/forcedamagemusic
BlinkyLights
Post by BlinkyLights » Thu Jan 07, 2021 12:38 am
Many great suggestions, thank you all.
Those PCBite holders are brilliant. The others tips, too.
Illiac
Post by Illiac » Thu Jan 07, 2021 12:47 am
Probably spent $150 on “disposable” irons, before getting a Hakko FX888 last year. One of the best purchases I’ve ever made.
skinpop
Post by skinpop » Thu Jan 07, 2021 1:30 am
+1 for the fx888. It's a pleasure to use. If you intend to use a tool for possibly hundreds of hours then you owe it to yourself to get something you'll enjoy using.
