Finally had free time at the end of that shitty past 2020 but at least I managed to finalise Discrete OTA filter on protoboard. Built using matched 2n3904 and 2n3906 transistors. Filter can be pushed in warm saturation with input volume, trough two pole low pass filter with band pass resonance and VCA at the end. It self oscillates, has an V/OCT input and with CV offset can be pushed down to few herts into LFO. When resonance is is pushed - it doesn't suffer from low frequency gain loss. Tracks well across 6 octaves. Has a Log FM and Linear VCA inputs with positive and negative volume pots. Audio output when pushed into saturation goes to +/-9Vpp but when running clean same 5Vpp and oscillates at +/-7Vpp. Levels can be brought back with output VCA. Works on +/-12V power supply (sorry MOTM users). I will soon try to record some demonstration video. Want to say thanks to fellow Wigglers who helped me before on this in this thread: Discrete OTA issues
Feel free to comment if you spot something weird or have an ideas how it could be improved with other bells and whistles.
Few comments and questions for experienced DIYers than me:
OTA cores are made with TL072 - not OPA 1662 as it is marked in drawing. Could be that there is a practical and audible reason to replace those TL072 op amps with lower bias / offset ones in the audio path? Does better op amps in audio chain makes such a difference?
OTA cores could be replaced with THAT 340. Haven't tested it yet but matched 2n3904/6 works fine.
Right now I wish that it could have better pitch stability. I made pitch controls with +/-9V voltage regulators and that improved a lot but some deviation is still going on. I suspect that the reason for pitch drifting are those Q12 Q13 Q14 transistors who needs to be closely matched and thermally coupled? Likely needs to have THAT 300 or similar? Maybe something else could improve pitch stability?
I tried but didn't found the way how to make High Frequency trim circuit for exponential converter.
Should I need to make linear FM CV input and Exponential VCA CV inputs as well? Doesn't have an idea right now - will I miss them in the future.
