Adding a sub oscillator to the Teisco 60F
wahee
Post by wahee » Sun Jan 10, 2021 2:13 pm
hi
I have successfully made a very simple 4024 based sub oscillator and have tested it on a scope and it does indeed put out division of the inputted square wave.
I wanted to add this to my 60f. I have successfully located the square wave output and the 4024 outputs a divided signal.
I have been having issues trying to inject the signal into the synth, and also how to mix it with the existing signal. After killing one 4024 I though it was better to stop and really get this right.
Attached is the schematic for the 110 model, 2 oscillator big brother of the 60f. I thought if I could inject at the filter it may be the right thing.
Just wondering if anyone more knowledgeable than me would have any insights
many thanks
Crystalline Stricture now on
tonnrecordings.com
guest
Re: Adding a sub oscillator to the Teisco 60F
Post by guest » Sun Jan 10, 2021 9:01 pm
replicate the circuits in the mixer section. add a resistor from the 4024 output to the top of a 50k or 10k pot, and then take a 100k from the wiper of that put into the mixer.
openmusiclabs.com
wahee
Post by wahee » Mon Jan 11, 2021 2:30 pm
hi managed to get it sorted. Did as you said.
I had to use quite a high value pot 500k. Then a 100k in and 47k out. Gave satisfactory levels.
The pot had an integrated switch so I can turn off the sub if required, sounds great
Quick vid:
tonnrecordings.com
guest
Post by guest » Mon Jan 11, 2021 4:53 pm
sounds great!
openmusiclabs.com
wahee
Post by wahee » Wed Jan 13, 2021 7:17 am
sounds great!
cheers, it's actually a decent mod to do
tonnrecordings.com
