Buchla 200X serie 208X build thread
I open this thread about the 208X build
Infos of the 200X série
https://www.muffwiggler.com/forum/viewt ... 7&t=243688
First bom :the PSU /Power Supply Unit for the 4UX boat
Pcb :micro psu used in the 4UX boat
Function 12V,-/+15V
Power switch,ground banana,12V lamp plug
IMPORTANT FOR THE PROMOTIONAL 208X BUNDLE KIT BUILDERS
THE 2 INDUCTORS NOS 120mH ARE INCLUDED IN THE KIT ,DONT BUY THEM (70-IHD3EB820L)
Bom PSU /Power Supply Unit +parts for the 4UX boat https://www.mouser.com/ProjectManager/P ... 98307abf80
208X Card 1 bom https://www.mouser.com/ProjectManager/P ... 757d40077f
208X card1 only X parts with 2N3904/2N3906 transistors turn them at 180 degrees on the pcb card1 V4 or use BC 550/BC 560 https://www.mouser.com/ProjectManager/P ... a3a0eea432
208X card2 bom https://www.mouser.com/ProjectManager/P ... 97297e4102
Function 12V,-/+15V
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
Re: Buchla 200X serie 208X built thread
The psu pcb (power supply unit)
Re: Buchla 200X serie 208X build thread
Card 1 +X parts Card 1 boms added
208X card 2 bom added
- Radiance2021
- Common Wiggler
Ive added the cards 1-2 build docs (parts number of an original 208) in the first post,you will use them to build the 208X
Build thread 208rev2 a lot of information
viewtopic.php?f=17&t=127084
- Radiance2021
- Common Wiggler
Seeing all these BOM's are for Mouser...has anyone ordered from them lately? (as in after Brexit?)
What are the shipping times?
I had an order at RS-Components which took 5 weeks to arrive due to stuff coming from their UK warehouse....
Mouser is in USARadiance2021 wrote: ↑Sun Feb 07, 2021 9:43 amSeeing all these BOM's are for Mouser...has anyone ordered from them lately? (as in after Brexit?)
I ve just ordered the last week
Order the Friday before 2pm,received the Monday before 1pm
Usa to France ,if your basket is above 50eu =free shipping,choose the option fees paid by mouser at checkout.Fast and no surprise at the delivery Pic of a basket of only 22eu (then a shipping has to be paid)
- Radiance2021
- Common Wiggler
Thanks les amis!
Your custom boat and vintage panel order is here
- Radiance2021
- Common Wiggler
Ive finished the card 1 and 2 mouser baskets (just missing ic sockets,there are expensives at Mouser)
Bom micro PSU /Power Supply Unit +parts for the 4UX boat
Mouser basket
https://www.mouser.com/ProjectManager/P ... F91FAC3D61
208X Card 1 v4 bom mouser basket
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 826CB6263B
Mouser basket
https://www.mouser.com/ProjectManager/P ... 6A86BF4F80
208X card2 V2 bom
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 1EB65FD006
208X card 3 V3
Ic socket missing
The 13M resistor is 12M+1M
https://www.mouser.com/ProjectManager/P ... 702DD698D0
The mouser basket links don't seem to work?boops wrote: ↑Fri Feb 19, 2021 7:13 am208X- 4UX-MICROPSU-AUX- NOISE- X MODS ALL BOMS.zip
Direct orders baskets:
Mouser basket
Ic socket missing
Mouser basket
208X card2 V2 bom
Ic socket missing
CorrectedDanaFo wrote: ↑Fri Feb 19, 2021 8:46 pmThe mouser basket links don't seem to work?boops wrote: ↑Fri Feb 19, 2021 7:13 am208X- 4UX-MICROPSU-AUX- NOISE- X MODS ALL BOMS.zip
Mouser basket
Ic socket missing
Mouser basket
208X card2 V2 bom
Ic socket missing
The links are always in the post 1
Open a mouser account ,load and save each projects,then you can manage your final order easily
For a project like this ,a local store can good,for some parts.
I like the pots at tayda ,you will find plenty of parts ,which are missing at mouser by exemple the colored caps,ic sockets,molex connectors ,some e switch toggle,etc
https://www.taydaelectronics.com/potent ... c.html?p=2
Small bear is great
http://smallbear-electronics.mybigcommerce.com/
Synthcube
https://synthcube.com/cart/
In Eu
Farnell
https://www.farnell.com/
https://www.musikding.de/
Digikey in US
https://www.digikey.fr/
For the reverb tank,in EU
https://www.banzaimusic.com/accutronics-1bc2e.html
For the blue 56 edge connector not included 2x28 pins
Google ebay 56 pins edge connector 2x28 pins
FOR BUNDLE KIT WITH AN ALUMINIUM PANEL ,NO 56 BLACK CONNECTOR INCLUDED ,BUY 2X BLUE 56
Example
https://www.ebay.fr/itm/1-PC-Cardedge-c ... 3809008169
TIME TO LEARN A LITTLE ABOUT PICKING SOURCING PARTS
Remenber ,you will use a lot the switches when playing your 208X!
For the toggle switches ,the best are CK/NKK,(In the MB V5 bom)APEM
E switch (mouser ,tayda )are fine ,cheaper,or you can use generic Banzai,small bear
Take time and check the bom ,learn from the datasheets
We need
DPDT ON-ON-ON
SPDT ON-OFF-ON
SPDT ON-ON
SPDT ON-OFF-(ON)
SPDT SINGLE PÔLE DOUBLE THRU
DPDT DOUBLE PÔLE DOUBLE THRU
ON/ON 2 POSITIONS
(ON) for momentary switch
Check the size of the shaft,size of the toggle itself
PC pin,SOLDER pin ,THE BOTH ARE OK WITH THE 208X MOTHERBOARD (MB)
SHARE YOUR LINKS HERE THEN I WILL CHECK THEM
A note about resistor ,capacitor often it is cheaper to buy at least 10 parts than 1or 2 parts.
Example
10 x 0,12 =1,2 eu
3 x 0,45 =1,35 eu
Ive done the first direct order card mouser baskets ,card 1 ,card 2,psu,X parts ,fyi the ref for the resistor has been changed ,as the old ref are sold only by 200 now.
Feel free to continue for the next cards 3 , 4, 5, etc and share your work,I will check it of course .
What is everyone planning to use for the VTL5C3 Vactrols? I've read that the decay on Xvive versions are not very good.
Hi,
I tried to make a Mouser basket for Card 3, but the resistors listed have to be ordered in multiples of 200 ! I'm pretty sure you wrote something about that but I can't find where ! ^^
Anyway, here's the basket :
https://www.mouser.com/ProjectManager/P ... 6d47d359df
I'd get resistors from tayda or even small bear. Very easy to order from tayda.ikkini wrote: ↑Sat Feb 20, 2021 11:28 amHi,
Greatikkini wrote: ↑Sat Feb 20, 2021 11:28 amHi,
Just above ,use the ref of the resistor in the card 1 basket,Koa brand
Ok, then I'll make a separate project for the resistors for all PCBs. It will be easier for me.
Basket for Card 4 (without resistors) :
https://www.mouser.com/ProjectManager/P ... 0e29bc8064
Basket for Card 5 (without resistors) :
https://www.mouser.com/ProjectManager/P ... a80691fb40
Oh great
Basket for Card 6 (without resistors), but the LM301 listed in the BOM is no longer available, could you give me the reference of an equivalent ?
https://www.mouser.com/ProjectManager/P ... ece0fa3c57
Ebay or local store
LM301
https://www.ebay.fr/itm/10-PCS-LM301AN- ... xyni9TFRMD
Your card 4 and 5 links give us the same basket
LM301
