Buchla 200X serie 208X build thread
Re: Buchla 200X serie 208X build thread
Ive finished the card 3 V3 link above too
https://www.mouser.com/ProjectManager/P ... a41ae128d7
For the resistance picking
Mouser
Koa brand 5%
Ex: 660-CF1/4CT52R104J is a 100k 104 -10 0000 ohms
For a 10k 660-CF1/4CT52R103j
For 1k 660-CF1/4CT52R102j
For 100R 660-CF1/4CT52R101j
For a 10R 660-CF1/4CT52R100j
Yageo brand cheaper
603-CFR-25JT-52-4K7
Mouser
Yageo 1%
603-MFR-25FBF52-28K7—28k7
TIPS
Use carbon 5% everywhere only
1% metal where it is needed
For the card 3,for the 13M
You can use in serie 12M+1M In the bom ,or 10M+3M available a tayda
Mouser
Koa brand 5%
Yageo brand cheaper
603-CFR-25JT-52-4K7
Mouser
Yageo 1%
TIPS
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
It’s possible but
Who has written that?
Did he make serious measurement or it’s just a feeling?
Thanks !
And the link has been updated for Card 5, sorry ! ^^
It seems that the decay might be too quick when using the Xvives, at least for the LPGs. Here's on video that I came across but it has been mentioned quite a bit:
viewtopic.php?p=3131563#p3131563
I also had some very nice email correspondence with Dave Brown about vactrols in general and in the 208 and he seems to feel that in cards 10 and 11, along with matching the vactrols the decay time is important in the LPGs for 'the classic LPG sound'. That's not to say they won't work but something that builders should be aware of. It doesnt seem like the decay/turn off time is as critical in other parts of the circuit but matching and selecting is.
Thanks for putting the Mouser carts together ikkini. It looks like for each card/motherboard, you're following the standard 208 BOM and not the 208x?
I'm following the BOM from the link by Boops, am I doing something wrong ?
Yes there are the boms for an original 208,with minor upgrades,like the zener diodes in the card cause, it’s possible with the 208X pcb to build an original one,without the crappy card 12,(this original card 12 is available,but I’ve didn’t ordered it)
There a separate bom for the X parts .,in the zip file above.
For the vactrols ,we have planed to measure a max of vactec vactrols ,in static and dynamic situation,we will try to recreate the 0ld ones.as always ,we run after the time
Many thanks Ikkini
I will add the resistors the next days ,at the end ,when we will add each basket ,we will have the final basket right.
Great !
Just to be sure I understand well, I have to add the components from the "X PARTS ONLY BOM REV1" file to my basket ?
They are not included in the other BOMs ?
Concerning the resistors, I've managed to group the one for the 12 cards and the motherboard in one file :
Exactly,these are the X parts needed for each new functions ,mods.You have to add them,I will create the direct mouser basket asap.
Great work about the resistors,to order at tayda ,I prefer to have a bom for each card,following the revision of the card example,card3 V3 bom.
ikkini wrote: ↑Sun Feb 21, 2021 5:17 pmGreat !
208X - resistors.pdf
These might also be good for the non-critical positions. They're 1/2 the price of the XVive's and might save builders some cash if you plan on buying extra's to match/select for various parts of the circuit. I plan on grabbing a bunch to test.
https://www.digikey.com/en/products/det ... AlNIC6AvkA
Yes, but the link you provided still refers to the resistors that must be bought in multiple of 200. That's why I did this document.
Check the resistors on first baskets card 1/2/3 I ve done.
Card 1 and 2 are ok, but Card 3 is still with the wrong resistors when I click on your link.
https://media.digikey.com/pdf/Data%20Sh ... SR3_DS.pdffallout wrote: ↑Sun Feb 21, 2021 5:41 pmThese might also be good for the non-critical positions. They're 1/2 the price of the XVive's and might save builders some cash if you plan on buying extra's to match/select for various parts of the circuit. I plan on grabbing a bunch to test.
that's the datasheet, my googling revealed that apparently they're much faster to turn on than the VTL5C3
there's a thread on muff started by Danjel/intellijel about finding vactrols and I believe they opted for nsl's as well.
Corrected a bad link,sorry.
Unfortunately,I can not edit the first post,not HANDY
important build links
https://www.modularsynthesis.com/roman/ ... card12.htm
https://www.modularsynthesis.com/roman/ ... 08spss.htm
viewtopic.php?f=17&t=211862
viewtopic.php?f=17&t=127084
basket link Resume the 23 02 21
Only X parts upgrades ,mods mouser basket ic socket +note
https://www.mouser.com/ProjectManager/P ... 73ba20dc43
Power Supply Unit micro pcb +parts for the 4UX boat basket link
https://www.mouser.com/ProjectManager/P ... 98307abf80
208X Card 1 basket link
https://www.mouser.com/ProjectManager/P ... 757d40077f
208X card1 only X parts with 2N3904/2N3906 transistors turn them at 180 degrees on the pcb card1 V4 or use BC 550/BC 560
Use it if you mod only your 208 card1 with our reset seq pcb
https://www.mouser.com/ProjectManager/P ... a3a0eea432
208X Seq reset infos
208X card 2 basket link
https://www.mouser.com/ProjectManager/P ... 97297e4102
208X card 3 V3 basket link
208X Card 4 V2 mouser basket added below with ic socket ( HQ reference ) updated the 27 02 21
https://www.mouser.com/ProjectManager/P ... 9d30a1480e
208X card 5 V2 mouser basket +ic socket
https://www.mouser.com/ProjectManager/P ... dbb38f5378
208X card 6 V2 the LM301 in the bom is Not available ,cancel it source it at Ebay by example.
https://www.mouser.com/ProjectManager/P ... 6bd99ad829
208X card 7 V3
https://www.mouser.com/ProjectManager/P ... e5d49c5d26
A note about resistors sourcing at mouser,the day of your order .
If ref 603-CFR-25JR-52-xx 25JB
is not available you can swap with
603-CFR-25JB-52-xx 25JR
The goal here is to have more than 10 resistors of the same ref to have the quantity discount.0,085 to 0,042
- Radiance2021
- Common Wiggler
Thanks! I'll look into this once I've received the goodies. Hope I can use some of my leftover parts from previous projects...for example, I've some 4000 series chips I bought when restoring my Prophet 5...4016 and such..
SOME MORE TIPS
About vactrol and matching
Use a VTL5C3/2 (x2) for the card 10 and 11,it’s a matched double VTL5C3 vactrol
Here how to wire them Some links for a low intensity ,low light led (should be changed in the MB basket Ikkini
https://www.mouser.fr/ProductDetail/Lit ... gTAY6Xo%3D
Or
For the tantalum,try to find some CTS brand NOS in your local store,at least for the C4 in card 11 ,a 47uF ,6,3V is fine (coupling inter stage capacitor,the audio signal pass thru),look like the silver ones. I prefer NOS ,axial film and ceramic caps ,too
Fyi,the sliders batch ,the new MB ,and new panel are on the way,shipping soon
Or
I changed the LEDs in the basket to the low light ones ! Thanks for my eyes !
This is all I could find that is reasonable for axial caps in that spec, how many does the full build require?boops wrote: ↑Mon Feb 22, 2021 5:20 amS
https://www.ebay.ca/itm/QTY-20-47uf-6-3 ... Sw~OdVaI68
https://www.ebay.ca/itm/Capacitor-tanta ... xyepRRvPzs
2 x 47uF tantalum 6,3 v polarised part
Be careful with the size ,old capacitor are bigger than modern.
The Vishay on the bom are fine ,too.
On the card 11 /208X the layout is 10mm space ,you can install it on the other side,(below) ,if needed.
208X parts only mouser basket +icSocket +note added in the resume post above
Here the note here ,feel free to ask questions
208X parts note
Molex 2,54 mm
Molex 2 pins for the reverb x2
Molex 4 pins for the aux/noise Card x2
Molex 3 pins for the noise /switch ore post x3
Male and female needed.
Tayda stocks the molex 2 ,3 and 4 pin ,male /female
Molex 08-50-0113 (Cut Strip) needed for the connectors above
By 100 in the mouser bom ,cheaper.
Banzai stocks some already crimped molex
https://www.banzaimusic.com/PCB-Connectors/
Noise 2 ic x1
https://electricdruid.net/product/noise ... generator/
TL074 X1 quad AOP
A better ic can be used like in the new card 12 (card 12X)
IC socket 2X7 X1
IC socket 2x4 X3
BLACK ROGAN small no skirted thonk UK black,white,blue ,red x2
Black banana x2. Sq rest cv,reverb cv,,then only 3 violet bananas in the MB bom(corrected)
https://www.mouser.com/ProjectManager/P ... 3BA7FCBA76
MB BOM corrected the 23 02 without switch/resistors
vactrol dip xvive vtl53 X1
1 x 3 mm red led ,added in the mouser bom ,then =10 a better price corrected in the MB bom 23 02 21
2n3904/2n3906 x1 in the mouser bom or tayda
The E-Switch 200MSP1T1B1M1QEH. Switches x3
Are smaller than standard ones.
Pre/post main volume (big rogan)
wfX
Step 2 seq.
208X parts note
Molex 2,54 mm
Noise 2 ic x1
TL074 X1 quad AOP
IC socket 2X7 X1
IC socket 2x4 X3
wfX
Step 2 seq.
This thread is getting confusing quickly. Can we condense all of the BOMs / Carts into 1 post for clarity?
