Buchla 200X serie 208X build thread
- Radiance2021
- Common Wiggler
Re: Buchla 200X serie 208X build thread
Great! Any more info on the PMB?
Hope to finish and release the next summer,the V1 works fine.switches,sliders of the 208 are all midi contrôlable,preset patches function ok,works with a midi keyboard and its functions,a max live app is done ,have to be deeply test it.Need some hardware tweak,and finish the final hardware version ,example inserted in a modern 218X
viewtopic.php?f=19&t=140876
My tip is to begin to build the psu and the 4UX boat (without the aux card pcb) to test your work
Then the mother board ,card 3 and 4 ,card 1 ,2 card 5,6 card11 card12 card 7,8,9,10,aux noise .
THE MICRO PSU pcb build pics The DC jack +12v red/Ground black
The pcb with all the parts soldered,clean the solder flux with essence F or other product ,not already done in the pics ;(
Use heat shrink for the 2x inductors,and each pin soldered.
The 4 molex connector is to power the aux /noise pcb
The standard Buchla wire colors are
ground quiet Q black
-15v white ,I use blue here
+15v red
12v green
+5v orange ,I use yellow here
Noisy ground brown
You should find -16V (for -15V) as the psu is not loaded.
Pass the dc jack thru the power square cutout Solder the hot red wire 12v lamp plug ,the ground should be done by the metal of the case/standoff
And solder the black ground banana on a ground pad on the pcb.
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
Only X parts upgrades ,mods mouser basket ic socket no toggles +note. Edited the 09 March 2021 (trimmer 50k has been changed)
https://www.mouser.com/ProjectManager/P ... 7045b7754b
Another standard external brick mouser link,a little bigger 12V,2,5 x5,5 mm plug ,+ centered
https://www.mouser.fr/ProductDetail/418 ... 12012E01VI
Thanks for the detailed pictures !
After the psu 100% ok ,build your mother board MB
Take your time ,if your mother board is 100% ok,you have done a lot of the job.
Begin by the 3 diodes and the resistors First Shipping in a few days
- Radiance2021
- Common Wiggler
208X card 11 V2 mouser basket
https://www.mouser.com/ProjectManager/P ... 657ec64297
I used to build the card 10 and 11 at the same time as they have a close design ,but you will need a lot of concentration .
208X card 12 V1 updated basket
For the 3x TO 220 insulator,an electronic local store is a good choice.
https://www.mouser.com/ProjectManager/P ... 47f1a5ba4e
Fyi,mouser is slower than before covid ,3/5 days
Trimmers (missing 2) ,cts 13 tantale capacitors like an origina,I use tropical caps ,too.
Ic sockets
Finally I put all the screws,nuts,washers needed in the hardware kit (you will need some (2)to fix your reverb frame +2 plastic washers under the 56 pins)
Ic sockets
Unfortunately,I can not edit the first post,not HANDY
Last thing to do is to compile all this baskets and look for and swap the unavailable parts for a complete order,I will do it asap.
All the boms ALL THE MOUSER BASKETS +HQ ic sockets last edit 11 March 2021
important build links
https://www.modularsynthesis.com/roman/ ... card12.htm
https://www.modularsynthesis.com/roman/ ... 08spss.htm
viewtopic.php?f=17&t=211862
viewtopic.php?f=17&t=127084
Optional :
A SINGLE 500K 504 TRIMMER (not added in the bom )IS NEEDED IF YOU WANT CONTROL THE TAPER (%) of the REVERB POT MIX in the MB mod R73 10k ,this mod is needed if you want add the reverb level mix cv in the monitor circuit too.
Power Supply Unit micro pcb +parts for the 4UX boat basket link
https://www.mouser.com/ProjectManager/P ... 98307abf80
208X Card 1 V4 basket link+HQ ic sockets
https://www.mouser.com/ProjectManager/P ... 7dff1aa857
208X card1 only X parts with 2N3904/2N3906 transistors turn them at 180 degrees on the pcb card1 V4 or use BC 550/BC 560
Use it if you mod only your 208 card1 with our reset seq pcb
https://www.mouser.com/ProjectManager/P ... a3a0eea432
208X Seq reset infos
208X card 2 V2 basket link +HQ ic socket
https://www.mouser.com/ProjectManager/P ... 866fc01c6c
208X card 3 V3 basket link +HQ ic socket
https://www.mouser.com/ProjectManager/P ... 2256a68a23
208X Card 4 V2 mouser basket added below with ic socket ( HQ reference )
https://www.mouser.com/ProjectManager/P ... 7542e6f3c7
208X card 5 V2 mouser basket +ic socket
https://www.mouser.com/ProjectManager/P ... dbb38f5378
208X card 6 V2 the LM301 in the bom is Not available ,cancel it source it at Ebay by example.
https://www.mouser.com/ProjectManager/P ... 6bd99ad829
208X card 7 V3
https://www.mouser.com/ProjectManager/P ... e5d49c5d26
208X card 8 V2
https://www.mouser.com/ProjectManager/P ... 0067dc32e0
208X card 9 V3 mouser basket the 3 x LM301 not included source them at ebay by example.
https://www.mouser.com/ProjectManager/P ... 7cc7872e16
208X card 10 V2 mouser basket
https://www.mouser.com/ProjectManager/P ... 2ea7960252
208X MB V4
https://www.mouser.com/ProjectManager/P ... 437dcaddff
Ive updated the 10 pins power connector for this one better quality imho
https://www.mouser.fr/ProductDetail/798-CR6-10S-3.96E
A note about resistors sourcing at mouser,the day of your order .
If ref 603-CFR-25JR-52-xx 25JB
is not available you can swap with
603-CFR-25JB-52-xx 25JR
The goal here is to have more than 10 resistors of the same ref to have the quantity discounted .0,085 to 0,042
All the toggles for the project 208X with the 4UX boat (aux card)included.
Medium quality E switch toggles +one CKK Mouser basket
https://www.mouser.com/ProjectManager/P ... c76751b569
Medium Quality E switch brand only toggles,mouser https://www.mouser.com/ProjectManager/P ... f6ddf2970f
CKK high quality ,recommended but expensive toggles switches +3 x mini serie 200 Eswith toggles mouser basket added
https://www.mouser.com/ProjectManager/P ... 5dc04490e9
Mountain switch brand is fine too.
I like the tayda electronics 9mm/16mm right angle pots
Small bear,Thonk is fine,too.
Cheap Colored caps
https://www.thonk.co.uk/shop/switchcaps-sub-mini/
4 colors Rogan knobs to customize your 208X
https://www.thonk.co.uk/shop/rogan-buchla/
For the vactrol ,I use Xvive VTL5C3 brand x11 for a complete 208X ,and 2 VTL5C3/2 for the card 10/card 11 (matched pair)
I offer the sliders ,stand-off,nuts washers ,screws in my harware kit,pm .
Optional :
208X card 7 V3
208X card 8 V2
208X MB V4
Cheap Colored caps
- Radiance2021
- Common Wiggler
Boops, where do you buy your coloured banana jacks? ..or did I miss something?
From Mouser I suppose :Radiance2021 wrote: ↑Sun Mar 14, 2021 10:46 amBoops, where do you buy your coloured banana jacks? ..or did I miss something?
https://www.mouser.fr/ProductDetail/530-108-0906-1
https://www.mouser.fr/ProductDetail/530-108-0910-1
You have all the panel parts in the mouser basket / bom 208X MB V4Radiance2021 wrote: ↑Sun Mar 14, 2021 10:46 amBoops, where do you buy your coloured banana jacks? ..or did I miss something?
Pomona banana brand
You can buy banana wire,jumper to patch at mouser, too
- Radiance2021
- Common Wiggler
Thanks, all is set for a smooth build. Awaiting the kit ....
Really soonRadiance2021 wrote: ↑Mon Mar 15, 2021 5:46 amThanks, all is set for a smooth build. Awaiting the kit ....
Infos about the sliders and toggle switches
If you have bought the hardware kit with the sliders ,you will receive 22 little pcbs to fit under the sliders
It’s top notch,these sliders are really steadies ,the MB traces are 100% isolated from the metal of the sliders.
It’s a lot of job,tests...but I’m really happy.
The colored caps (if you use standard ones ) are above around 1mm of the panel,here the black from tayda
For the toggle switch. You have to test them before installation,check carefully the parts numbers when you install them example:(SPDT on-on and on-off-on )
Check the position of your momentary switches x2 ,pulse trig and reset seq ,there are différents,solder ONLY ONE PIN ,up to you will install the panel,the same with the sliders only two pins up and down.Install only one nuts on the toggle switch at the right level with the nuts Tool you will install the second
Nut against the panel .USE TWO NUTS BY TOGGLE !!!!
Pics
- Radiance2021
- Common Wiggler
That PCB is a great solution for the different sliders!
Eh oui ! ;)Qui cherche trouve des solutions,au lieu de copier bêtement.Radiance2021 wrote: ↑Mon Mar 15, 2021 1:54 pmThat PCB is a great solution for the different sliders!
I don’t like the alps sliders,there are designed to be fixed under a panel ,not only on a pcb.
A ton of Pomona here my mouser basket !
https://www.mouser.com/ProjectManager/P ... 522ce172bc
Shorting dual banana
https://www.mouser.fr/ProductDetail/Mue ... nh7A%3D%3D
https://www.mouser.fr/ProductDetail/Pom ... Ki9w%3D%3D
https://www.mouser.fr/ProductDetail/Mue ... 6RcQ%3D%3D
Optional :
A SINGLE 500K 504 TRIMMER (not added in the bom )IS NEEDED IF YOU WANT CONTROL THE TAPER (%) of the REVERB POT MIX in the MB mod R73 10k ,this mod is needed if you want to add the reverb level mix cv in the monitor circuit too.
My toggle switch nuts leveler TOOL ,use one standoff which is used for your panel ,(included in the hardware kit) and a large washer.
Adjust the first nut under the washer at the right height.
Optional :
Some update in the only X parts mouser basket
C1X-C2X 10uf
Tr10X 10k
Tr11X 500k
C9 C10 100nf
Added
All the infos in the first post.
C1X-C2X 10uf
Tr10X 10k
Tr11X 500k
C9 C10 100nf
Added
- Wiggling with Experience
- Contact:
When was the last time you tried? According to this thread: viewtopic.php?f=11&t=244256
This is working for me.
Dunnington Audio - Various Buchla format accoutrements available
Great. Many Thanks
First post edited with all the last infos,boms,mouser baskets.
Put a blob of solder pin7
I use a blue wire for the -15V,the standard is white.
I use the same color wires than bananas,then I can test the 208X without the panel,once the leds (soldered with the panel assembled) sliders,toggles,pots are finished to be soldered.
- Radiance2021
- Common Wiggler
Thanks for the detailed build instructions...looking good!
