SSI2140 Filter Overdrive
lickspittle
Post by lickspittle » Tue Feb 16, 2021 11:15 am
Hi,
I'm looking for some advice on driving an SSI2140 filter ic.
The data sheet recommends a peak input signal of 2V p-p (with its reference design) but adds "Higher input levels overdrive the input stage, resulting in a distortion that many will find desirable. See [xxx] for further discussion." [xxx] appears to be a placeholder.
Does anyone have any idea of what the maximum input level should be limited to? The overdriven distortion is a good part of what makes this filter desirable but I don't want to break it.
oldenjon
Re: SSI2140 Filter Overdrive
Post by oldenjon » Tue Feb 16, 2021 3:28 pm
Nobody answered this? I think you should be fine with any input voltage due to the 10K/200R voltage dividers. Hopefully someone with a bit more expertise will come and confirm that.
"We all dance by ourselves, that's why we only play electronic music"
http://synthscalledbeasts.tumblr.com/
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Feb 17, 2021 5:40 am
Hopefully Neil Johnson will chime in, but you won't break it by feeding in a large signal.
Curious to hear too as I've got a simple proto design board coming shortly - didn't have the scope to put an onboard drive control but will experiment with external pre-level control to see the responses.
lickspittle
Post by lickspittle » Wed Feb 17, 2021 6:23 am
Thanks oldenjon and BugBrand,
Ideally I'd like to see THD/Frequency curves for various amounts of Vin but I don't have the test equipment.
Eventually I'd like to use the SSI2140 for what guitarists call "playable distortion" which they (rightly) consider desirable and which I've never seen on a synth. I'm hoping that velocity controlled drive will do the trick.
lickspittle
Post by lickspittle » Wed Feb 17, 2021 7:25 am
...or...
Possibly more elegant, change the usual subtractive synth flow from VCO -> VCF -> VCA to VCO -> VCA -> VCF where nothing goes through the VCF until the gate opens. Assuming that the VCA envelope is velocity sensitive, it might be interesting.
Any thoughts?
edit:- Maybe not, the clipping would ruin the dynamics.
neil.johnson
Post by neil.johnson » Wed Feb 17, 2021 2:21 pm
What you really mean is the input signal level to the gm cell input, which you would normally keep below +/- 20mV. In the example circuit the 10k/200R attenuator allows that circuit to handle a 2Vp-p signal without distorting. If you have a hotter signal then increase the 10k resistor to suit.
Generally it's not a great idea to put the filter after the VCA otherwise you will get filter noise even when not playing anything.
If you want to overdrive the input then you can do so by pushing up the input signal a bit so that the first gm cell input is overdriven and distorts. Make sure this is to your taste ;)
In a forthcoming update (don't ask when, m'kay) to the data sheet there will be a circuit which allows you to control filter overdrive without changing the output signal level.
Neil
Random ramblings :: http://www.njohnson.co.uk
SSI parts and more :: https://www.cesyg.co.uk
oldenjon
Post by oldenjon » Wed Feb 17, 2021 2:26 pm
But assuming that distortion is desired, you'd want to use hotter signal with the 10K/220R. Isn't that the point? I thought a big part of hype around SSM2040 is the unique asymmetric distortion as described in AN701.
neil.johnson
Post by neil.johnson » Wed Feb 17, 2021 2:59 pm
Well, you can either use a hotter signal with the 10k/200R input, or if you don't have a hotter signal you can reduce the 10k resistor to drive the input harder. Not every application of the SSI2140 has +/- 12V rails so you have to use what you have - the key point being driving the gm cell input beyond 20mV.
Neil
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Feb 17, 2021 6:49 pm
In a forthcoming update (don't ask when, m'kay) to the data sheet there will be a circuit which allows you to control filter overdrive without changing the output signal level...
Any brief hints/outlines on how this will be achieved? ;)
neil.johnson
Post by neil.johnson » Wed Feb 17, 2021 7:11 pm
Spoilers!
lickspittle
Post by lickspittle » Wed Feb 17, 2021 7:38 pm
I don't understand this, Neil (not uncommon). Isn't the maximum peak to peak set by the onset of clipping?
BugBrand
Knowledge of Bugs
Post by BugBrand » Thu Feb 18, 2021 4:17 am
Spoilers!
Tease!
Fingers crossed for the updated datasheet - not that I really need more projects to delve into at the moment..
neil.johnson
Post by neil.johnson » Thu Feb 18, 2021 5:48 am
Here's the helicopter view: SSI2164 on the way in, SSI2164 on the way out, diode-limited inverter on the CV to the second VCA. So when you amplify the input signal you attenuate the output signal to keep the levels the same. The diode limit is needed to counter the clipping action of the gm's input stage.
Neil
BugBrand
Knowledge of Bugs
Post by BugBrand » Thu Feb 18, 2021 6:08 am
Cool - thanks Neil.
That won't upend my current simple 1-space test idea which should be able to be set as one of LP/HP/BP/AP easily enough.
But likely a useful idea for a larger future design.
neil.johnson
Post by neil.johnson » Thu Feb 18, 2021 2:57 pm
No, that's only when the Q is turned up. In this case we're talking about the input stage which you can overdrive for a pleasing overdriven distortion effect.
Neil
lickspittle
Post by lickspittle » Thu Feb 18, 2021 3:13 pm
Neil
Is this a different distortion mechanism to the asymmetric soft-clipping outlined in AN701?
neil.johnson
Post by neil.johnson » Thu Feb 18, 2021 3:38 pm
Neil
Yes.
Neil
lickspittle
Post by lickspittle » Thu Feb 18, 2021 4:13 pm
Ok, thanks Neil. I look forward to the updated datasheet.
