Hello,
I'm in the process of making a graphic equalizer module (hopefully 5 or 6 band) for my rack. After a bit of research into different kinds of filter circuits, the following two pole active filter from Dale's Homemade Robotics stood out to me:
The website even has a nifty calculator for calculating the resistor values based on a fixed capacitor value.
https://www.wa4dsy.net/robot/bandpass-filter-calc
I decided to breadboard up this circuit for testing purposes. For my initial test, I decided to use a TL072 op-amp powered by a 12VDC external supply with the following parameters:
Center frequency: 1kHz
3dB frequency: 233Hz
Q-factor: 4.3
C1,2=0.1uF (ceramic)
R1= 6.8kΩ (trimpot)
R2=190Ω (trimpot)
R3=13.6kΩ (trimpot)
Voltage Gain: 1
I inputted an audio signal from my rack (a "strum" from 2HP Pluck) and outputted the filtered audio to my rack's audio out, as I would any other module.
However, there was no discernable difference in the filtered audio wrt the original sound. At first, I thought the op-amp was fried, but retesting with a TL084 gave the same results. Next, I tried switching to electrolytic capacitors, but the same thing. I even tried changing the parameters for a higher voltage gain, but the audio still sounded unfiltered, just a bit louder.
This has me thinking that maybe I need to add something to this circuit in order to hear the results. I should note that, as part of my EQ circuit as a whole, this "filtered audio" will eventually be fed into a voltage controlled amplifier, before being mixed together with the rest of the filtered audio from the other bands, via a summer circuit.
Along those lines, I decided to take the output of this circuit and pass it through a unity amplifier (simple inverting op-amp config with 100k resistors). The output oddly was static, overlaid with audio that sounded quasi-filtered.
It appears something isn't quite right with the way the audio is getting filtered, but I cannot seem to figure it out.
Does anyone have any ideas as to what the problem could be?
Edit: to fix R3 resistor value from 13.6 to 13.6k
Troubleshooting EQ/bandpass circuit
- Uncle Peter
- Learning to Wiggle
- Contact:
Re: Troubleshooting EQ/bandpass circuit
Maybe it's just me, but the cap values seem a little high... what if you switched them to 10nf or lower?
Also, the "oddly static" output sounds like some sort of clipping? Can you do a scope trace before and after?
"Noise is what the Earth is made of" - David Bowie
- neil.johnson
- Super Deluxe Wiggler
- Contact:
Not sure if it's a typo but R3 should be 13.6 kilo ohms.
Nice little Deliyannis filter
Neil
Neil
- neil.johnson
- Contact:
What does the output look like on a scope?
Neil
Neil
- SphericalSound
- Wiggling with Experience
You can look at the monotropa circuit by reverselandfill. It has the resistors and caps values for a lot of bands and IIRC he uses that same bandpass typology.
Finaly the monotropa has a last opamp that feedback the output into the input and turns the whole thing into a evil analogic warming and destruction thing. I use it in every patch
- Uncle Peter
- Contact:
SphericalSound, thank you for that info, will definitely be checking out that circuit. Need to hammer down these values before I begin building.
Neil, thanks for spotting that typo, I have fixed it.
djs, I took your advice and swapped out the cap with a lower one (I only had 1nFs on hand and unfortunately no oscilloscope). It did reduce the static I was hearing down to a hum now. That got me thinking that it was perhaps a power supply issue, so I swapped out my 12VDC supply and took +-12V directly from my eurorack, and it fixed the problem. I could now hear the filtered audio with no background noise or static! Seems that was the problem all along. Thanks for the tip!
I did also have a question about band spacing for a graphic equalizer. Since module size is limited, I've decided that I could get away with 6 or 7 bands at the most on the module. Is there a generic rule for how to properly space the bands? I've heard of overlapping the bandwidths, but I think I would have to reduce the Q-factor of the filter to accomplish this.
Here's a quick frequency response I put together showing the gains of band that I chose: 100, 200, 400, 800, 1600 and 3200Hz bands with a Q-factor of 1.7, along with 10nF caps and resistances ranging from 1.8k - 550kΩ. A -3dB dashed line is also plotted to reference bandwidths.
Again my main concern is trying to balance numbers of bands with Q-factor, such that each band will actually be effective at filterting, yet when all the bands are summed together, the original audio signal is replicated as much as possible.
