For the power supply, there is the option of using an internal mains transformer (in my case, to go from 120VAC to 15VAC) or an external AC-AC adapter. Depending on what kind of case I end up with I might eventually use an internal transformer, but for now I plan on using an external adapter.
My question relates to this passage in the construction guide:
This is the wiring diagram forJ8: My AC adapter has a two-prong plug and provides two outputs. Am I wrong in thinking that there is no 0V connection? Does it matter how the two outputs are connected to J8? AC power is a real mystery to me.The standard method of connecting a mains adapter to the 9090 would be using a low voltage barrel-type connector, often referred to as ‘DC power’ connectors. They are available in a small number of sizes; 2.1 or 2.5mm internal pin diameter connectors would be ideal here. Your AC adapter may already have a suitable plug attached, so you will require a matching socket for that. The socket is then wired to pins 2 and 4 on connector J8. If your socket has a metal body mounted against a metal chassis, then it is essential that J8, pin 2 (0V) is connected to the outer shroud (outer contact) of the socket. Otherwise excessive hum or even damage could result.
Thanks a billion.
