Haible Trapezoid - Works too well!
cnicht
Post by cnicht » Wed Feb 24, 2021 11:03 am
I’ve built a stripboard version of the Haible Trapezoid generator and it constantly cycles irrespective of the setting of the ‘OFF’ pot.
The controls all work and the manual trigger functions if the cycle is in an off phase to trigger the output waveform.
I’ve tried changing some of the bias resistors round the window comparator and the differential pair transistors are ‘reasonably’ well matched.
Any thoughts? What might cause this behaviour?
I’ve built a couple of the discrete versions of this and it was equal fun getting them to cycle!
A ‘two pipe problem’?
Edit: Reduced R19 to 680k now it’s off, triggerable and cyclable
vladosh
Re: Haible Trapezoid - Works too well!
Post by vladosh » Wed Apr 07, 2021 7:50 am
i had in mind to build this for long time now ,and i wonder a little thing ,on the LM394 the first collector connects to +V or ground ,not sure cause elsewhere on the scheme +V is labeled +ve ? Thanks
edit: jus checked the original synthi schematic so it connects to ground i seems
cnicht
Post by cnicht » Fri Apr 09, 2021 5:37 am
It does connect to GND and I used a pair of transistors which I matched
vladosh
Post by vladosh » Fri Apr 09, 2021 3:27 pm
made a layout for this using BCM847
cnicht
Post by cnicht » Fri Apr 09, 2021 3:48 pm
That’s excellent! I built mine on stripboard as I just needed a one-off.
There is a PCB available for it at Modular Addict
