Interesting low parts count VCF
TedGettsterby
Post by TedGettsterby » Tue Mar 30, 2021 2:31 pm
Just want to draw folks’ attention to this one opamp expo vcf:
https://www.elektormagazine.com/labs/an ... -one-opamp
the author mentions that it has potential polysynth applications and that they are working on a full synth voice design based on this filter
guest
Re: Interesting low parts count VCF
Post by guest » Tue Mar 30, 2021 2:46 pm
thanks for posting that! for anyone else looking to dig in, here is more info on it:
https://tudl1086.home.xs4all.nl/synthci ... tpvoks.htm
openmusiclabs.com
MikeDB
Post by MikeDB » Tue Mar 30, 2021 5:33 pm
We used to do something similar with the LM346. You programmed frequency with the Set A/B/D pin, and Q with the set C pin. I expect the TS271 has a wider range though.
jorg
Post by jorg » Wed Mar 31, 2021 9:23 am
Nice! I hadn't seen this chip - I thought the magic Polivoks chip was unobtainium. Mouser is stocking TS271, TS272 (dual), and TS274 (quad). All are about $0.62, quantity 1 (depending on the variant chosen).
Exciting stuff.
devinw1
Post by devinw1 » Wed Mar 31, 2021 11:35 am
That's pretty cool. I remember reading about that old Russian op amp a long time ago. Pretty cool somebody found a modern chip that can be operated like this. That certainly is dead simple.
lickspittle
Post by lickspittle » Wed Mar 31, 2021 11:41 am
Paired with a simple AD envelope generator, it might make a nice, vactrol free, Low Pass Gate.
deftinwulf
Post by deftinwulf » Wed Mar 31, 2021 11:44 am
Noob curiosity question: What is 1V/V? Does that read "1 volt per volt"? What is the significance of that specification?
Feel free to PM if this is derailing the thread.
jorg
Post by jorg » Wed Mar 31, 2021 12:07 pm
1 Volt out for 1 Volt in; i.e. a gain of 1.
deftinwulf
Post by deftinwulf » Wed Mar 31, 2021 1:06 pm
Cool, thank you. I'm intrigued to see what new VCF designs evolve from this discovery with the TS271!
jorg
Post by jorg » Wed Mar 31, 2021 1:48 pm
Has anybody found a decent SPICE model for the TS271? The one from ST Microelectronics omits the bias input (the one thing that matters about the part!).
guest
Post by guest » Wed Mar 31, 2021 4:09 pm
i was pretty happy to see a programmable opamp as well, i didnt know they were still a thing. unfortunately, the TS272 and TS274 are different opamps. i couldnt locate any other programmables in dual or quad. that LM346 looked like quite the chip.
openmusiclabs.com
MikeDB
Post by MikeDB » Wed Mar 31, 2021 4:58 pm
The LM346 has been around since the 70s and is still around on the surplus market. Problem was at low currents it distorted, and wasn't shall we say 100% stable at higher currents. The XR-095 BIFET version was a great improvement with the amps programmed in pairs, but Exar are long gone.
There's a few articles from people claiming to have 'discovered' it and are the first to use it in a synth. Sorry guys - 3 to 4 decades too late
jorg
Post by jorg » Thu Apr 01, 2021 7:46 am
Yeah, on closer inspection, the TS272 and TS274 omit the bias pin! They are sold in 3 different fixed-bias variants. :doh:
SkyWriter
Post by SkyWriter » Thu Apr 01, 2021 7:54 am
There's always PAIA's old low parts count transistor designs. 1T LP and a 2T BP.
https://electro-music.com/wiki/pmwiki.p ... 0BPFAndLPF
I built these guys with TV parts when I was a kid.
Prologue 16 - an adventure worth having!
jorg
Post by jorg » Thu Apr 01, 2021 8:14 am
Those are super cute! :love:
sublimiter
Post by sublimiter » Thu Apr 01, 2021 8:20 am
very interesting. will absolutely be adding a handful of TS271s to my next mouser order.
KSS
Post by KSS » Sun Apr 04, 2021 7:29 pm
Surprised not see anyone mentionthe 4250 programmable OPA. Those have been doing cloning duty in polivoks filters for a long time.
KSS
Post by KSS » Sun Apr 04, 2021 7:39 pm
The BPF is worth making. Add the range switches seen in a mod article in Polyphony. <--They're now mostly all online.
But the LPF is pretty dismal. Even its designer called it more of a tone control than proper synth LPF. Try a 'similar' Steiner VCF instead. Or even better, a moog ladder. The mmg's -/+10V is close enough to PAIAs -/+9V that it just works. Once you hear PAIA's unijunction based VCOs -like a 901- through moogs 24dB LPF you'll wonder -or finally understand- why PAIA gets little love. But everyone shold read their Docs. Those are a great and under-utilized synth learning resource!
guest
Post by guest » Sun Apr 04, 2021 7:54 pm
i tried searching for other PGAs out there, but the modern definition is a digitally switched opamp, and maybe variable gain amplifier (VGA) is the new term? the 4250 doesnt seem to be an active part, but you can get the LM359, i wonder if that would work?
openmusiclabs.com
KSS
Post by KSS » Sun Apr 04, 2021 8:48 pm
That's an interesting part. It's a Norton, so CDA. But it's a dual with Iset going to both amps. Certainly worth a try in a filter app.
But also for any old 3900 apps, based on the DS improvenent claims over 3900. Quad v dual but might be worth getting a few and re-visiting some old designs.
The 4250 is still out there if you know where to look, but i was surprised it's as far off the beaten path as it appears to be now.
guest
Post by guest » Sun Apr 04, 2021 9:08 pm
and in case anyone is keeping a list of these, the OP-32 is still available.
openmusiclabs.com
nigel
Post by nigel » Sun Apr 04, 2021 11:04 pm
I got several 4250s from Tayda a while ago to build a Polivox-ish VCF. Checking now, they are still listed, but out of stock.
vladosh
Post by vladosh » Mon Apr 05, 2021 5:48 am
i got a bunch of 4250's from ali and built this vcf ,second time
