PSU 3 Problem
youwe9
PSU 3 Problem
Post by youwe9 » Tue Apr 06, 2021 10:36 am
Hi,
I am building a case with 2 Doepfer PSU 3. Each has it´s own powercable. One is working fine, but the other one is doing some strange blinking.
And the module connected to the busboard is not working...
See the video..
I did the same wiring on both PSUs.
As I know nothing about electric circuits, I don´t know, what could be wrong or broken, the PSU, the busboard, the wiring...?
Maybe someone can help me
Thank you!
EATyourGUITAR
has no life
Re: PSU 3 Problem
Post by EATyourGUITAR » Tue Apr 06, 2021 10:55 am
disconnect the modules. same problem? disconnect the bus board. same problem? if yes then it is the psu. if no then it must be the bus board or the module. this is pretty easy to diagnose.
youwe9
Re: PSU 3 Problem
Post by youwe9 » Wed Apr 07, 2021 9:37 am
Thank you!
The PSU 3 was broken...
