Generating CV/Gate with Arduino
chrismuller86
Post by chrismuller86 » Fri Mar 02, 2018 11:32 am
Hi all,
:help:
I seem to have problems interfacing the DAC8565 using my ESP32 dev board. Using a multimeter I measure 3.2V at all 4 outputs constantly, though in my code I try to change between 2 voltages:
LDAC, ENABLE, RSTSEL connected to GND
I've connected the DAC8565 like this:
ESP32 -> DAC8565
IO5 (SS) -> 9, SYNC
IO18 (SCK) -> 10, SCLK
IO23 (MOSI) -> 11, DIN
IO15 (RST) -> 13, RST
GND -> LDAC, ENABLE, RSTSEL, GND
3V3 -> AVDD, IOVDD,VREFL
Would be amazing if someone can help me out!
Seele
Re: Generating CV/Gate with Arduino
Post by Seele » Sat Aug 01, 2020 4:59 am
Hi there,
as a short introduction - I‘m pretty new to eurorack, not so very new to arduino and a huge fan of everything involving keys, strings and making noise ;)
I know this is an old thread, but it‘s probably the best place to ask:
I‘m currently building a cv/trigger sequencer using an arduino and several adafruit neotrellis put together as a led matrix controller.
My plan is to have eight independent trigger outputs for triggering eurorack drum modules.
I already experimented with generating triggers from a quad channel DAC (MCP4728), simple filtered PWM signals and also plain unfiltered PWM signals from the arduino.
So far, I can‘t see any difference in the results of these three methods for generating very short (approx. 5ms) cv/trigger signals.
I have however noticed that for generating cv/pitch or cv/control signals (which I did in another project) you have to use a DAC or otherwise your synth will do all kinds of funny stuff.
Can anyone explain to me, why I should maybe use a DAC for cv/trigger anyway, or if it‘s maybe okay to use plain PWM signals in this case?
Best, S.
Sandrine
Post by Sandrine » Sat Aug 01, 2020 10:53 am
Perhaps he should have used a union instead of those shifts which may be causing an issue:
Code: Select all
union z_tag {
  byte u[4];//lsb to msb "little endian"
 unsigned long uval; // example Serial.print(z.fval,HEX);
} z;
A DAC is needed only for the analog CV, the Gate/Trig portion can be purely digital (preferably buffered first!)
Using a DAC for a trigger is inefficient as it's slower (amp slew) and requires more code...unless the outputs are multi-purpose configurable...
PWM is way too slow for changes in level (because of the PWM-DC filtering circuit) only useful for LED brightness or vactrol control stuff.
nrrrd
Post by nrrrd » Sat Aug 01, 2020 12:35 pm
I don’t think I’ve ever seen an example of using 8 to 12 of the digital pins on an Arduino, plus a r2r ladder dac, for an analogue or CV output. Is there a reason for this? Does it just use too many pins?
It seems like a good solution, using 1% resistors, but there may be something I’m not getting.
nigel
Post by nigel » Sat Aug 01, 2020 8:55 pm
I suspect that using up that many pins on a single output seems a bit inefficient. If you only need a single output though, it should work.
One problem may be the accuracy - 8 bits is 256, so the bottom bit would be less than 1/2% of the full range. I'm not sure exactly how the output of a resistor ladder depends on the accuracy of the resistors, but intuitively I would expect that you would need 0.1% resistors to get anything close to linear. 12 bits would require 0.01% or better. At some point it's easier to just buy a decent DAC chip.
Seele
Post by Seele » Sun Aug 02, 2020 4:28 am
Is a voltage follower sufficient for buffering the trigger signals or do you need something special for this?
nrrrd
Post by nrrrd » Sun Aug 02, 2020 4:34 am
An opamp will have some slew, the amount depending on the model of the opamp. A simple alternative solution is to use a npn transistor as a switch, like in the CGS Gated Comparator module (and countless others, but this is where I saw it first)
Seele
Post by Seele » Sun Aug 02, 2020 4:56 am
Thank you!
Source: https://sdiy.info/wiki/CGS_gated_comparator
