Any chance you could post the schematic of these sections (for comparison), perhaps I can cobble something for my old rev board to work this newer way.thx2112 wrote:I've been doing the same sort of tests.
Based on this information the latest revision of the PCB has BAT54S/current-limiting resistor instead of transistor.
Euclidean Polyrhythm generator - code and details
- daynehacks
- Common Wiggler
- Contact:
- nevetsokyeron
- Wiggling with Experience
- Contact:
yes - all 3 trigger outs are the same voltage.thx2112 wrote:Any luck? I've been trying to (unsuccessfully) recreate the problem.
Are all of the trigger outs the same voltage?
Are all the related components the right value?
What's the voltage at the transistor end of the 10K resistor?
yes - all related components are the right values
Voltage going into the transistor is 5v. At the 10K it's hard to get a voltage reading with my multimeter. It looks similar to the pulse output of the transistor. I'll see if I can check it on my Zeroscope later.
Could the pulse voltage from the Nano be the problem? Which pin would I look at?
Note - I've got the Euclid2-20 PCB
- daynehacks
- Common Wiggler
- Contact:
daynehacks wrote:Any chance you could post the schematic of these sections (for comparison), perhaps I can cobble something for my old rev board to work this newer way.thx2112 wrote:I've been doing the same sort of tests.
- thx2112
- Veteran Wiggler
- Contact:
Sorry, I thought I answered this and just saw that I didn't.
Here's the schematic for the new PCB:
The only differences are:
1. BAT54S instead of transistors on the outputs.
2. Circuitry for 3 analog/digital inputs or digital outputs, including jacks. These are wired to A5, A6, and A7 through previous expansion port (which is still there).
The code is exactly the same. Nothing has been done with the code except to verify that the new analog inputs work. The panels will also need new holes drilled for the jacks.
If anyone is interested I have knocked up a pattern sequencer based on this hardware. It mostly mimics the Euclidean (and at some point I might try and bash the two together) so 3 tracks and an offbeat output that is the inverse of track 1.
The main differences are:
* The density control is now used to define a pattern.
* You have to hold down an encoder for ~2s (and release) to switch the active track - a quick click (and release) performs an edit action.
It is pretty simple at the moment and very much a work in progress, but my light weight testing suggests it is functional.
You can find it here on GitHub. The read me provides some more info on what the controls do.
If you do give it a go, please feel free to highlight any issues.
I have made some updates to this, knocking a few items off my todo list along the way.duff wrote:If anyone is interested I have knocked up a pattern sequencer based on this hardware. It mostly mimics the Euclidean (and at some point I might try and bash the two together) so 3 tracks and an offbeat output that is the inverse of track 1.
This sketch now supports (on a per track basis):
* Euclidean or programmed patterns
* Forwards, Backwards, Pendulum and Random play
* Clock divider
* Output width - Short Trigger, Matching Clock width or a Gate whilst the step is active
I have also changed the way a playing track displays. The the whole track is now visible with a cursor running along it. I'm not sure if I like this though so I might change it back to how the original euclidean worked or make this a selectable option.
As before, more detail is availablehere on GitHub
Note - This is still a work in progress so there may well be a bug or two in there that I have missed. If anyone is trying this please feel free to feed back issues, pain points, ideas etc..
Not sure if anyone is reading this, but if you are I have just added shuffle. This can be set on a track by track basis. It works on both internal and external clock sources and is similar to the shuffle on a 909. In my (probably biased view) it really livens up programmed and Euclidean sequences.
As before details on GitHub and feel free to feedback issues and ideas. I'm particularly interested in views on how the user interface could be improved to help make editing more informative. Although with an 8x8 led matrix the options are always going to somewhat limited.
- nevetsokyeron
- Contact:
NEAT! I'll give this a test run later in the week.duff wrote:Not sure if anyone is reading this, but if you are I have just added shuffle. This can be set on a track by track basis. It works on both internal and external clock sources and is similar to the shuffle on a 909. In my (probably biased view) it really livens up programmed and Euclidean sequences.
If you have any issues then please let me know - it all works for me, but I think I am the only one to have run it so far.nevetsokyeron wrote:NEAT! I'll give this a test run later in the week.duff wrote:Not sure if anyone is reading this, but if you are I have just added shuffle. This can be set on a track by track basis. It works on both internal and external clock sources and is similar to the shuffle on a 909. In my (probably biased view) it really livens up programmed and Euclidean sequences.
I added another feature that provides evolving or subtling differing steps sequences - somewhat inspired by the Turinging Machine. On each loop, on a track by track basis, it will randomly invert steps in the sequence. You can set a weighting as to how likely it is steps will be inverted (0 to 50%) and you can choose whether this random mutation is derived from original pattern, the current mutated pattern, or the inverse of the current mutation.
- nevetsokyeron
- Contact:
A couple notes on trying duff's alternate firmware:
1. Arduino nano USB driver thingy causes a kernal panic on MacOS Sierra.
A fixed driver is here: https://github.com/adrianmihalko/ch340g ... s-x-driver
2. LEDcontrol and Encoder are not installed by default with Arduino so those need to be installed. Might make note of that in the readme. You probably already have these if you installed Tombola's firmware. (I did the install on a different machine and did not have these libs installed).
- Common Wiggler
Can someone give me the nickle tour rundown on the state of this module. I'm thinking I'll build one but I'm hopelessly confused.
I've read the thread but maybe I don't understand, there seems to be several versions of the code with different capabilities. The hardware seems to be fairly simple, but is there any "official" software?
Try the Syinsi website for a matching schematic/PCB and GitHub repo. I guess this might be deemed the 'official' version.CLee wrote:Can someone give me the nickle tour rundown on the state of this module. I'm thinking I'll build one but I'm hopelessly confused.
* I think the tombola repo is historic and fixes have not been patched back.
* The sneakthief repo is similar to syinsi's but they aren't quite the same. I'm not sure it works with the syinsi schematic/PCB as I haven't tried it.
* My repo contains code that adds some extra features as an alternative to the syinsi repo - possibly too many though and as such aptly demonstrates the limitations of using an 8x8 matrix as a display.
What code did you flash?klangbauer wrote:Two issuse in my Euclidian Sequencer V2:1.05 dfsg2-4:
Offset is not working on Seq 1 (only one time after start up). Other channels are working.
To stop a sequence: Lenth and Events (N and K) has to be zero.
Output LED is still flashing. I expected: Chanel is muted if N=0!
Any idea?
- Common Wiggler
I jused both version: THX and SnakeThief. After loading both versions serveral times I think:
Snake Thief version don´t had that problem. But if you change
(int length = 50; //was 50 -pulse length)
a bit you can´t change offset of channel 1 anymore.
I tried to control puls length to 60 to get a better response of encoders.
OK: Where is the parameter to change encoder response without force described issue?
klangbaukoeln
klangbaukoeln
- Common Wiggler
I haven't but I only used the THX code and my own code, not the SneakThief code you suggested you were using.klangbauer wrote:Error is back.
Chanel 1 Offset is not working stabel. Sometimes it works or not.
Reset Atmel helps and it works.
I use an Arduino Pro Mini without USB to progamm it seriell. It is a cheap thing from China and works in many other applications without problem.
No one discover this issue?
Are you sure it is only impacting channel 1? Or does it impact the channel being edited which happens to be channel 1?
If it is the edited channel I would suggest checking the soldering, the encoder, and verifying you aren't getting any odd signals at the input pin.
- Common Wiggler
It is mostly channel 1 and new also channel 3. After reset it is working and suddenly it refeuses to do.
As far I understand, you suggest a hardware problem. OK.
What you mean "getting any odd signals at the input pin" of Arduino?
I my schematic a 7805 feed Arduino and LED Matrix. THX feed 12V in Arduino RAW input and feed 5V seperat to LEDs.
This is the difference and it may be a reason to get dirt in one of Arduinos input.
OK it is a trace worth to evaluate.
Thank you
Thank you
- Common Wiggler
I tested to seperate power supply for LED and Arduino. 12V to Arduino RAW and 5V only for LED Matrix and driver.
Same story.
Powering up "Offset" of channel 1 is working only one time. After restart Arduino seperatly, it works.
Can't measure any "dirt signals" on assosiated PIN's D9/10
All other chanels are working.
Magic
Same story.
Magic
- Common Wiggler
Offset Chanel 1
At the moment I think it is a EEPROM issue.
What means:
void setup .......
// IF THE NANO FAILS TO BOOT (DUE TO CORRUPT EEPROM), COMMENT OUT FOLLOWING IF AND END BRACKET
// TO FORCE NEW EEPROM WRITE.
Any help?
What means:
void setup .......
Any help?
