Buchalish 111 Ring Mod PCBs
Fernando
Post by Fernando » Tue Oct 30, 2018 7:43 pm
ok, thank you Bbob
Fer
fluxmonkey
Post by fluxmonkey » Sun Sep 01, 2019 9:54 am
Big shoutout to Mike Peake for pointing out an error on my Buchla RingMod boards... one of the resistors marked 10r should in fact be 10k. I and others have successfully built these with the marked values, but trimming will be easier with the correction. I've updated the build page with errata and pics. Thanks, Mike!
This and all my other Buchla clone PCBs (110 Voltage Controlled Gate, 111 Ring Modulator, 160 Noise, 180 Attack Generator, 194 Bandpass Filter, and the Random Voltage Generator from the 208) are still available cheap for true DIY heads.
and I'm always expanding the documentation section of the historic buchla (100/200 series) pages, with more schematics and notes. Please let me know if you have other information to share!
happy wiggling!
www.fluxmonkey.com
Peake
I'm in ur DIY. Filling cases with Buchla
Post by Peake » Sun Sep 01, 2019 8:54 pm
You can never tell if the schematics are correct, glad this makes a positive difference! A little bit deeper into the machine...
Fluxmonkey PCBs are awesome for mixing and matching 100 System functions to make use of otherwise mostly blank 1U panels, such as a module mixing a 194 and a dual 110, for example. There's panel art in this forum for Lazertran water slide decals you can mix and match and bake for yourself.
viewtopic.php?p=2671917
Below: Using Fluxmonkey 208 Random and 160 Noise PCBs on a single panel:
This is not the place I'd imagined it to be.
Delabelle
Re: Buchalish 111 Ring Mod PCBs
Post by Delabelle » Tue Feb 16, 2021 4:19 am
From where do you get the -15v that is not available on the Buchla 100 system?
fluxmonkey
Post by fluxmonkey » Wed Feb 17, 2021 10:27 pm
-15 is not used on on this module, so you can leave it unconnected. I only kept the connector for consistency, for folks who have mixed 100/200 series systems.
www.fluxmonkey.com
djs
Post by djs » Wed Feb 17, 2021 10:54 pm
Speaking of mix and match- this one has a 208 random voltages and noise from fluxmonkey. Plus half of a 156 that I made myself (untested yet)
"Noise is what the Earth is made of" - David Bowie
Delabelle
Post by Delabelle » Thu Feb 18, 2021 4:05 am
Fab and nice panel btw
I ll test with a transfo that delivers +-15v derived from the available 15v plus share ground
Delabelle
Post by Delabelle » Thu Feb 18, 2021 5:08 pm
I'll drop this idea and go for a fluxmonkey pcb if no -15V is needed.
Delabelle
Post by Delabelle » Fri Feb 19, 2021 12:21 am
But when I see the blurry pcb example on the fluxmonkey shop there is that 68k connection to -15v. Or am I wrong?
djs
Post by djs » Fri Feb 19, 2021 12:58 pm
Zooming in on the pcb, the header for -v is there, but not connected to anything. Which would match the schematic for no -V needed:
Delabelle
Post by Delabelle » Sat Feb 20, 2021 4:54 pm
Ok thx, I ll order a pcb at Fluxmonkey
It is weird because I have another version from electro-music forum where the -15v is needed.
Moos Gummi
Post by Moos Gummi » Sun Feb 21, 2021 10:43 am
This thread is about the ring modulator, which doesn´t need -15V. The random source needs a negative supply.
Delabelle
Post by Delabelle » Mon Feb 22, 2021 12:48 am
Correct, my bad and now I know ;)
Delabelle
Re:
Post by Delabelle » Mon Feb 22, 2021 12:52 am
happy wiggling!
Grant Richter has uploaded loads of schematics in the Buchla FB group
Moos Gummi
Post by Moos Gummi » Mon Feb 22, 2021 1:07 pm
I think the random source should work on a single supply as well if you replace the weird LM3900 XOR with a CD4030 or 70. Maybe replace the outputs with LM324. But I absolutely don´t get the point of the 4016 at the gate input. Were they really expansive back then and Buchla couldn´t stand the thought of letting one of the swtches go unused?
fluxmonkey
Re: Re:
Post by fluxmonkey » Mon Feb 22, 2021 8:52 pm
happy wiggling!
With Grant's permission, I cleaned up his scans and they are now indexed & included on the fluxmonkey pages. THANKS GRANT!
www.fluxmonkey.com
Don T
Re: Re:
Post by Don T » Mon Feb 22, 2021 10:25 pm
happy wiggling!
Hold on, a Buchla FB group? There seem to be a few, which one is referred to above?
Delabelle
Re: Re:
Post by Delabelle » Wed Feb 24, 2021 12:04 am
There are only 2 it’s the normal not the official one.
Tap Grant and you’ll see the pictures ;)
