Buchalish 111 Ring Mod PCBs
- appliancide
- Super Deluxe Wiggler
heya appliancide - yeah I think it's a bit cleaner ring mod sound with the attenuated, and there is more usable play with the couple trimmers that I found to be useful. Been a couple weeks I've been using it and I think it's a lovely ringmod. Check out both though - I'm sure some may prefer the grittier non-attenuated - I've kind of found a middle ground I like with the help of that 20k trimmer.
- FetidEye
- demonic space drone
- Contact:
the bom says 4x 10k, but on the pcb it says 2x 10k and 2x 10r
what should i use? or is it a typo?
and about matching the transistors:
can i buy matched pairs , or is it easy to match 'm myself?
i checked out this pdf: match but it would be great if someone can help me with this.. (i'm not so good with math)
breadboard pics anyone?
bom errors:
there are 4 x 1k5 (instead of 1) resistors on the pcb
missing: 10uf condensator
bom errors:
- fluxmonkey
- Contact:
Project documentation and PCB component values are correct... i fixed the BOM on the first page of this thread.
- hexinverter
- the nettles make me think happy times
That is a complex subject, but, Ian Fritz has a nice .PDF article on what I consider the easiest and best method of transistor matching. A search should turn it upFetidEye wrote:ok
any tips on the matching?
EDIT d'oh, the one you linked is the one that I am referring to.
There is no math needed really...it's just subtraction if I recall correctly. You don't have to fully understand his mathematical explanation there -- just skip to the important bits so you understand how to match them based on his guide
Hexinverter Électronique
em: stacy[at]hexinverter.net
I just got my board (THANKS!) but I don't really grok this.fluxmonkey wrote:yep, that's an optional passive voltage divider for folks using this in conjunction w/ non-buchla modules. they'd need to drop the input signals, and then boost the output w/ a buffer amplifier--suggested values based on ken stone's stomp box adapter which is what i used in my testing. omit both pairs and use In1 and In2 for buchla (1.2v) levels.bsmith wrote:Did want to ask about optional attenuated ins...
RA 22k x2 (optional input attenuators)
RB 1k x2 (optional input attenuators)
looks like we can have standing resistors on either side of a pad for ins there - how is this meant to be wired for attenuation?
I thought ring mod was for audio chain, not control chain, so why would 1.2V matter?
I'm using a 15V mostly MOTM format systems, mostly Thomas Henry modules.
- appliancide
That isn't a reference to the 1.2V/Oct standard of Buchla. Apparently the audio signals are about 1.2Vp-p, compared to the 10Vp-p signals used in most other systems.elmegil wrote:
- djangosfire
- dimensionally transcendental
Hi guys -
I'm putting together a Mouser order for this 111 pcb.
I still get confused when it comes to capacitors . . . .
What voltage range should I be concerned with?
Looks like electrolytic is OK in place of the tantalum ??
Also, there appears to be 4x 1k trimmers?? And 1x 20k trimmer?? The BOM does not say.
Any help/tips greatly appreciated.
Thanks very much!!
- Adam
Thanks very much!!
- Adam
Djangosfire - new Adam Scramstad Acoustic Finger-style Album:
https://adamscramstad.bandcamp.com/releases
- fluxmonkey
- Contact:
i always use electolytics rather than tant... works fine, but i can't give an informed opinion on if it sounds any different. for that matter, i've always used 4.7uf instead of the specified 5.6... again, seems to work fine.
and yes, sorry, the trimmers are missing from the BOM. as stated, you need four 1k and one 20k trimmers per board: 3299Y-1-102LF and 3299Y-1-203LF from mouser. i'll get the doc revised, my apologies.
djangosfire wrote:Hi guys -
Thanks very much!!
- Adam
- fluxmonkey
- Contact:
sorry, that's a copy/paste fail. i never made a FPD panel for this one--mine's still sitting behind a piece of raw blank aluminum. 2 in, 2 out, how hard can it be?
raisinbag wrote:Hey flux, just looking at your site and there seems to be a "link" to a frac fpd panel design, but it isn't activated. Can you shoot me a copy? I'm on a panel etching junkit this weekend.just lookIng for some ideas for where to start this one.
- prscrptn
Having a problem and wonder if anyone can help...
My 111 has a low frequency hum around 180Hz which is present regardless of any signal on the input. This is the second unit that I've built and the first one had no issues.
I am using the same components/values and have checked all traces and adjusted trimmers. The problem is present on both boards and I have tested them independently, same issue...
Any thoughts?
Any thoughts?
- fluxmonkey
- Contact:
So I also replied to your PM, but
1) I haven't actually built this circuit
2) I didn't remember you saying both boards, so each ring mod is a separate board? If so my advice in PM isn't worth much :-)
My speculation would be something wrong with the tantalum caps, but that's a total SWAG and I'd check flux's question about the Power Supply first.
- fluxmonkey
- Contact:
