remember that buchla uses different audio levels than doepfer; you will need to attenuate signals going in, and boost going out, to interface w/ euromckenic wrote:Watching this with interest as the Euro chaps take the plunge and hopefully give the all clear - then I can jump!
Buchalish 111 Ring Mod PCBs
- fluxmonkey
- Super Deluxe Wiggler
- Contact:
- fluxmonkey
- Contact:
- fluxmonkey
- Contact:
i used ken stone's stompbox adapter when testing, worked a treat. current version has 3 makeup amps on the board, and the option to cut it down to just the 2 you'd need, to save space. i will add pass-thru pads so you can interconnect power, and maybe (optional) attenuator voltage dividers on the inputs.
if anybody else didn't realize that this was a buchla module, and wants to back out of the buy, please let me know so i can adjust the count.
I don't want to bail, no way! I just want. To use the opportunity to add a usefull attn/ amp to make this usefull for my purposes. Do you think just a 100k pot feeding some signal to grd to Attn the input signal would work? What about this ditty as an amp for way out viewtopic.php?t=71645
I would just need a bit of help to choose the right components. This kind of thing should be easy enough to build on perf board quick.
- bakedcircuit
- Common Wiggler
- ChrisR
- Veteran Wiggler
Thanks, appreciated!fluxmonkey wrote:my experience w/ the trimmers is that they are not critical settings: for a couple of them at extreme settings you start getting some distortion, but there's a pretty wide range in the middle where they seem to make very little audible difference.
the 2 outputs appear to be 180deg out of synch w/ each other, other than that, they sound about the same. if you mix them both together they cancel each other out.
Buy the ticket - take the ride.
- fluxmonkey
- Contact:
boards are in the house, i am doing one final reference build to QA... have had a bunch of gigs this weekend, so it probably will be a few more days before i'm done.
once they're verified, i'll put up an ordering web page on th fluxmonkey.com site, w/ a paypal shopping cart (if i can figure that damn thing out), and post a link here. when that goes up, it will be first come first served, so no need to post any more adds or changes here.
thanks everyone for your interest, patience, and support!
b
b
- fluxmonkey
- Contact:
- fluxmonkey
- Contact:
final QA done, finally ready to take orders! First post updated w/ ordering instructions [go to http://www.fluxmonkey.com/fluxmerch.htm to purchase boards]. Thanks everyone for your patience and support!
bbob drake
bbob drake
- freeyerheel
- Veteran Wiggler
+1
plus one for me please
